Like Tree195Likes
Novarossi engines thread
Old 10-26-2010 | 10:38 AM
  #3766
Originally Posted by Geberit
Can anibody tell me what's the technicall difference between the .12 Flash and 353 .12/C Tuned? Which motor is the top runner of Novarossi? Maybe the 353? It has better characteristics on Novarossi homepage!?
Regards, Lojz
I'm just getting started with RC's and needed a engine for my sprint car. I ordered the 353Race C tuned, it should be here any day now. hand-tuned lightweight crankshaft plus various laser engravings on the cooling head and crankshaft.
Sprint Doctor is offline
Old 10-27-2010 | 06:37 PM
  #3767
Friggen packing person! I got my engine about an hour ago and they sent me a .21 kangroo I notified them about there mistake. Gotta have the 353race C tuned.
Old 10-27-2010 | 07:44 PM
  #3768
Default S21WCS09
Hi,
Just completed running in my S21WCS09.
Engine comes with C6TF plug.
I am in a country where ambient temperature is approximately 32 degree celsius year round.
Will the nova C7TGF plug be more suited given the environment I am running the engine in?
Sam
sammies is offline
Old 11-19-2010 | 03:40 PM
  #3769
RC MARKET's Avatar
Some engine arrived Free Air Parcel
RC MARKET is offline
Old 11-19-2010 | 06:12 PM
  #3770
Originally Posted by sammies
Hi,
Sam
If it runs a bit too hot, then go for the C7. If where you live is pretty humid, then maybe you should stick to the 6, but if its dry, then I would go the C7.
DJ_Shakespear is offline
Old 11-20-2010 | 12:47 AM
  #3771
MRX4XXXX's Avatar
Hi,
Sam
You can do the break-in with the #6, but after that change it to #7 or even #8 depending on the track.
-X-
"-9Celsius today and snowing "
MRX4XXXX is offline
Old 11-25-2010 | 08:33 AM
  #3772
Have a question got this engine today. The side has a label says Flash .21 Special Factory Tuned and Break In. ????
Is it real or just a gimmick??
Does it mean i don't have to run in and just tuned and go or is there a procedure to use it.
This is my second Nova, (1st is a Flash .21 Special Factory tuned).
Romeo is offline
Old 11-25-2010 | 09:38 AM
  #3773
RC MARKET's Avatar
this one ?
Old 11-25-2010 | 10:52 AM
  #3774
Chickentrader's Avatar
Tuned means tuned for higher performance in this case (ceramic bearings, more attention to crank balance and cylinder sleeve porting), and it does not mean that you can leave mixture adjustments the way that they are. With factory break-in engines; you should still run engines rich until the piston feels like its not running very tight.
Kindest regards,
Lars.
Chickentrader is offline
Old 11-25-2010 | 07:02 PM
  #3775
the factory tuned means that Novarossi modifies the crankshaft to optimize the performance of the engine better than the none tuned version.
the breakin version assures you that the engnie broken in correctly,you also get a data sheet card that tells you the specs of the engine,honestly this is the best version you can buy cause this assures you that your engine has no defects in the fit and its a plus that you dont have to spend the time doing it, the broken in engnies will require 500cc of fuel more and its ready to race tune it .
this version of engnie is done by the same person in Novarossi that does all the Team engines so it not a gimmick ,honestly this as close as you will get to the same engnies as the factory guys use .
Roniel_R is offline
Old 11-26-2010 | 09:59 AM
  #3776
Thank you now i understand better so just run 500cc of fuel like running in manner and then cool it down and start race tuning. Oh boy this will be far easier than what i use before. I be sticking to these kind of engine.
Thank you all for the kind advise.
+1 Novarossi
Romeo is offline
Old 11-27-2010 | 04:12 AM
  #3777
NitroWD's Avatar
Default plugs
what other plugs are suitable for nova engines?
NitroWD is offline
Old 11-27-2010 | 11:27 AM
  #3778
It is different for different engines and running conditions. We use Nova C5TGC or C5TCH; for Novarossi 353, 3SCT or Flash 12 engines, but most of the guys around here use Nova C6TGC or C6TGH turbo plugs. Many around here believe that ODonnell plugs are better (and much cheaper), and we have also used them at times. Use ODonnell 77 to replace the Nova 5. or ODonnell 99 instead of the Nova 6. We use O.S. No 8 glow plugs for a Nova CX12 (non turbo plug head).
The information in the file attachment should help. Please note that C (calda) and H (hot) is the same in Novarossi turbo plugs.
Kindest regards,
Lars
File Type: pdf
Old 11-27-2010 | 03:00 PM
  #3779
Stuff Of Legend's Avatar
Thumbs up
Kindest regards,
Lars
Stuff Of Legend is offline
Old 11-29-2010 | 02:54 AM
  #3780
NitroWD's Avatar
Kindest regards,
Lars
thanks Lars, but what i meant is what other brands of plugs could fit the nova engines nicely?
NitroWD is offline
