Novarossi engines thread
#257
Originally posted by warpig
it's the spray bar adjustment.. it moves the venturi position back and forth for different air/fuel flow patterns.. makes minor adjustments to rpm gains... only for very experienced tuners.. you could ruin your engine if you don't tune the whole assembly correctly... easily throw it into a lean setting...
#259
the plug is a restrictor.. you do not want to remove that... if you do you need to replace it with another size.. the stock one is the best though.. I run a P5 Turbo also.. an 2050 pipe... a novarossi gold 6 turbo plug... not one problem.. the engine is so fast and reliable it's silly... I'd ditch the plug and try another... but, I have never heard of an engine firing up backwards after it was just running correctly
Thx warpig
I will leave the red plug alone and I have ordered 2No Novarossi gold 6 turbo plug's
I'm glad that Psi find's this funny
But for me knowing little about 2 Stroke,s It seem's too me that a engine changing direction after running one way to the other would be a worryand would make sence to talk to people that might be in the know
As it turn's out no one so far has had this happen to them which is good but seem's to make my event seem silly
Any how happlly since then it has'nt happened but I have gone through another glow plug which i think was the wrong one (Os p6) runnig with the rossi 7 till the new one's come
#260
Originally posted by Storm
Thx warpig
Thx warpig
I'm sorry for laughing at the situation.
What car do you have?
Do you have a car that has reverse?
Maybe it's not the engine and it's your car that's giving you the problem.
#261
Thx warpig
Thx warpig
#262
Originally posted by Top Gun 777
It happens, when engine is realy too reach, but it should switch direction back to normal after cranckcase been cleared. Unless there is some "bubu" made during cranckshaft manufacturing-check shaft and compare with other engines.
Thx Top Gun
I have no engine's to compare .
But i've been out with me buggie all morning and it has'nt happened once
I,ve got the engine working how I would like it apart from when I take my finger of the throtal it slowly dies's down to tick over
I've found that after putting after run oil in the carb it returns faster ,Is there any type of oil or grease you can put on this shaft ?
#263
Originally posted by PSI Racing
Storm,
Storm,
No problem dude
I have a new Kyosho Kanai 3 , novarossi P5T, Futaba S9402's this being my first buggie......... and then seeing the thing go backwards did freak me out after spending near on a thousand pounds on this rig
But I think all is well now
#264
No problem dude
No problem dude
Top Gun 777 said it does happen when it's too rich.
Try leaning it out.
If you need help with leaning it out, I'm sure one of your local guys could help you tune your engine.
#266
Anyone know where to get the info on Novarossi turbo plugs. I've seen it before where it lists all the plugs and it's characteristics with part #. Instead of going to the LHS and saying I need a medium plug blah blah blah. I'd like the specific plug number.
#267
glad to hear someone else running a turbo.. mine is unbeliebable.. I have a P5T... just an amazing engine..
I've been running the novarossi C6TGF plug.. it is a high end version of the novarossi 6 turbo plug.. it did run smoother after I replaced the stock one with it... good luck
#268
Can someone please help
i need to know where to set all the carb needles as a starting
point as i have touched all the adjustments & having problems
now (lost) getting back to a starting point.
#269
#270
Novarossi Top TSR12S3
Hi guys,
wonder what is the TSR12S3 ...is it the same a NSR12S3?
What is the difference between the Novarossi and the Top Line?
I am confused...
It's right there ...http://cgi.ebay.com/ws/eBayISAPI.dll...EBWA%3AIT&rd=1
Is it ROAR legal?
I am confused...
Is it ROAR legal?
195Likes
