Need help finding Lipo for Airtronics MX-3x?
Which LiPo/'s will fit and work with an Airtronics MX-3x transmitter? I see some are 2 cell and some 3s. Will this 3 cell work and fit properly?
http://www.amainhobbies.com/product_...k-111V-2300mAh
Does more cells give you longer run time or just the bigger mAh rating?
Just need some suggestions on the best (longest lasting) LiPo that will actually fit in the battery tray of the MX-3X.
Thanks!
Thanks!
No, thats too high voltage. Radio has the option to use a 2S lipo or 2S LiFe, not a 3S. Owners manual pgs 9, 11 and 46.
More cells is higher voltage - 2S = 7.4v nominal, and 8.4v fully charged, 3S = 11.1v nominal, 12.6v fully charged, 4S = 14.8v nominal, 16.8v fully charged and so on....
Longer run time is higher capacity (mah).....
Ok, thanks! So what is a LiPo that will fit the MX-3X?
i use the venom 3000 11.1 lipo in mine i have the fhss-2 but there is no diff between the 2 from just looking at them so it should fit with no problem much lighter too i havent charged my pack in 2 months lol
[IMG][/IMG]
[IMG][/IMG]
