Need help finding Lipo for Airtronics MX-3x? >
Old 11-08-2010, 09:38 AM
Default Need help finding Lipo for Airtronics MX-3x?
Which LiPo/'s will fit and work with an Airtronics MX-3x transmitter? I see some are 2 cell and some 3s. Will this 3 cell work and fit properly?
http://www.amainhobbies.com/product_...k-111V-2300mAh
Does more cells give you longer run time or just the bigger mAh rating?
Just need some suggestions on the best (longest lasting) LiPo that will actually fit in the battery tray of the MX-3X.
Thanks!
BestNThDez is offline
Old 11-08-2010, 09:54 AM
Trader Rating: 21 (100%+)
No, thats too high voltage. Radio has the option to use a 2S lipo or 2S LiFe, not a 3S. Owners manual pgs 9, 11 and 46.
More cells is higher voltage - 2S = 7.4v nominal, and 8.4v fully charged, 3S = 11.1v nominal, 12.6v fully charged, 4S = 14.8v nominal, 16.8v fully charged and so on....
Longer run time is higher capacity (mah).....
Duster_360 is offline
Old 11-08-2010, 10:19 AM
Ok, thanks! So what is a LiPo that will fit the MX-3X?
Old 11-08-2010, 01:11 PM
C Verano's Avatar
You can use this one.
http://www.hobbypeople.net/index.php...10-3x-11x.html
C Verano is offline
Old 11-08-2010, 08:15 PM
So, then would this one work instead?
http://www.amainhobbies.com/product_...-Balancer-Plug
Old 11-09-2010, 04:52 AM
It looks like it would be too big compared to the other one that does say it fits the MX-3X.
Old 11-11-2010, 01:46 PM
i use the venom 3000 11.1 lipo in mine i have the fhss-2 but there is no diff between the 2 from just looking at them so it should fit with no problem much lighter too i havent charged my pack in 2 months lol
[IMG][/IMG]
toyota 2jz is offline
