Tamiya mini cooper
Julius,
I use anti-wear grease on the splines to assist with remaining in the diff drives. I have stripped my fair share of TAO3 ball diff splines I now use a short length of fuel tube in place of the "o" ring. You just have to ensure you get no binding from the universal/dogbone when the suspension is altered. (Thanks Grandpa, for the Top Tip).
Michael,
We found today that the spool is not as fast at SMA as the gear diff or the ball diff. Great acceleration as you stated, however you lose to much corner speed.
Tyres and car setup also play a huge role in how fast you can be, especally when you factor in the drivers input.
However, I believe that a solution to the diff problem maybe only a couple of months away max.
Can not say more.
Later,
Calvin.
Michael,
Can not say more.Later,
Calvin.
Julius,
Michael,
Can not say more.
Later,
Calvin.
Michael,
Calvin.
Thanks for the info, I hope you had a great day's racing...
Will you be mini racing this friday night ?? If you are, i'll push to get there.
That would make for a decent 4/5 car battle for TQ !!!
Your little teaser sounds interesting, I wonder if it is along the lines of what i'm working on at the moment for my M-05 ??
Michael.
buy my car, save cash and have it ready race w/all the trick bits on it now instead of buyin upgrades as you hear about them or they finish in front of you in the 1st couple wks.
and if not my car, i suggest highly buyin some1s old TCS ride...much better way to go indeed and less $$$$. they are tricky lil things w/their own nuances, why not let some1 else take the headaches for you.
R
R
R
R
Hi. I ran an M-05 but still interested in getting an M03. My question is: Is it easy to convert an M-03M to the short version by simply not installing or removing the plastic insert that goes with it? Or do I have to purchase another part for me to do so. I want to run the old Mini Cooper body with it which I think is only for the short chassis. Thanks for any info guys. Edwin
Well, after years of running M03s, I have finally put my first M05 together. It's all bearings and has Tamiya aluminum steering link 54192. It runs great and the steering is dead on. I couldn't be happier with it, BUT, the black can motor is pretty lazy.
So tonight I ordered the Hobbywing 35a 13t motor/ESC combo from Hong Kong after doing some research in this thread. You guys are a big help on here. Not sure how long it will take to get here (I'm in California).
Anyway, my question is.... It looks like the shaft is longer on the Hobbywing motor than on the Sport Tuned... Will I have to do some chassis modding to accommodate the longer shaft? And one more... Is the fan for the ESC really necessary? Temps in this part of California can easily get over 100f in the summer.
Thanks in advance.
Thanks in advance.
Thanks in advance.
Thanks in advance.
Nope no mods required, the Hobbywing motor fits straight in. Just make sure you use the pinion mounting thingy that comes with the kit.
Thanks in advance.
Thanks in advance.
. That's < 38* C. So you're pretty safe to leave it off.I've heard of guys running their speedy inside the rear chassis extension on the m03.
Cheers,
Peter
What are your views on Tamiya M05 ball diff 54194, is it ok with out mods, or do you need to change some of the parts. Only ever used gear diff so far, but clubs I race at in UK now allow ball diff’s. Have a 3-racing ball diff as well but waiting for mod parts before I use it.
thank you in advance
Ben
Ben
295Likes
