hudy break-in bench
Old 11-02-2010 | 07:45 PM
  #16
nitrozilla's Avatar
bump
nitrozilla is offline
Old 11-13-2010 | 05:23 PM
  #17
guntek18's Avatar
BUILT MY OWN ,
FROM SCRATCH , JUST TO SAY I COULD, HAS COST ME $25.00 TOTAL.
SOME PARTS OLD SPARES, FUEL TANK WAS DONATED. WOULD HAVE BEEN $15.00 IF SALESMAN HAD NOT SOLD ME THE WRONG PROP ADAPTER, WHICH I HAVE NOT RETURNED... excited about using it. using a 3/4 deep socket on a drill , got robber insert from hardware store and drilled it to a tapered shape to match prop. cone.
BRAND NEW : "JL .21 PRO" ON THE BENCH.
Attached Thumbnails hudy break-in bench-img00076.jpg   hudy break-in bench-img00075.jpg   hudy break-in bench-img00074.jpg
guntek18 is offline
Old 11-13-2010 | 05:45 PM
  #18
jpalessi's Avatar
good if you can mount to a bench that dont vibrate much. also needs a larger prop. you dont need a drill or plane starter. just use your finger.
jpalessi is offline
Old 11-13-2010 | 06:05 PM
  #19
guntek18's Avatar
platform is a scrap piece of 1/4 inch thick aluminum, 14' square. Pretty flat with soft rubber foot pads at all four corners. doubt that it will budge but if it does, ill just break out the small c-clamps and secure it.
guntek18 is offline
Old 11-14-2010 | 09:39 AM
  #20
Integra's Avatar
You'll want to clamp it down when running, It WILL vibrate around on the table. And IMO you dont need a bigger prop, the Hudy/Nanda/RD logics props are very similar in size....As long as the motor cant spool the prop SUPER easily you'll be fine. Not too sure what "pitch" the standard Bench prop is But it looks to be close to what you got there.
Integra is offline
Old 11-14-2010 | 10:05 AM
  #21
awdcameolsx's Avatar
What part number prop and prop adapter are you using?
awdcameolsx is offline
Old 11-14-2010 | 02:14 PM
  #22
jwm2's Avatar
Originally Posted by guntek18
BUILT MY OWN ,
Awesome, where did you get the surround for the prop? I might just give it a try if i can find the right parts.
jwm2 is offline
Old 11-14-2010 | 03:26 PM
  #23
guntek18's Avatar
supposedly i was given the max-pitch prop.
guntek18 is offline
Old 11-14-2010 | 03:32 PM
  #24
The prop that comes with the Hudy is marked 240-17. It has been cut down to 120 mm.
bentgear is offline
Old 11-14-2010 | 03:51 PM
  #25
guntek18's Avatar
thanks for the technical info, will follow up on that.
guntek18 is offline
Old 11-14-2010 | 04:01 PM
  #26
You can buy the RD Logics break-in bench parts
(prop,adapter,nut,cowl) separately. Here is a link
to the parts:http://www.rdlogics.com/cgi-bin/cate...tegory=Engines
rageworks is offline
Old 11-14-2010 | 04:33 PM
  #27
guntek18's Avatar
Sorry about late responses to earlier questions,
the prop and adapter came from hobby-town. just make sure prop. adapter fits a 5 mm. shaft and has a nose-cone for a nut.
prop. : approx $3.00
prop adapter : approx $8.00
the fan guard is from the ends used to ship rolls of laminates.
I can get those all day long. anyone wanna tackle a cool project like this and need the fan guard, let me know.
guntek18 is offline
