6 mm venturi for NOSRAM/Orion/Picco engine >
Old 10-10-2010 | 02:02 AM
Lille-bror's Avatar
Default 6 mm venturi for NOSRAM/Orion/Picco engine
Hi.
I really need a 6 mm venturi for my NOSRAM engine. The engine (carburator) are similar to Picco Evo 2 turbo, LRP 21X, Orion CRF 21 and JPX21.
Here is the original NOSRAM 7 mm venturi:
As you can see, the NOSRAM venturi is different from Novarossi (yellow) venturies:
Will this fit my carburator?
http://www.amainhobbies.com/product_...1-60mm-Venturi
Thanks in advance, gentlemen
Lille-bror is offline
Old 10-10-2010 | 04:16 AM
Ambros303's Avatar
Originally Posted by Lille-bror
Hi.
They might not fit as the old Orion engines were Picco based but the new Orion Alpha ones are Star / Sirio Based.
This one will probably fit, but it's 7mm:
http://www.amainhobbies.com/product_...tor-Insert-7mm
Not sure, but doesnt the Picco Boost have a 6mm venturi? That one might fit.
Edit: Just checked: the Picco Boost has a 6mm venturi.
Ambros303 is offline
Old 10-10-2010 | 06:21 AM
Lille-bror's Avatar
Hi.
Thank you very much.
I've send the Scandinavian distributor of Picco engines an email
Old 10-10-2010 | 10:34 AM
Lille-bror's Avatar
Did you find the partnumber?
Old 10-10-2010 | 10:45 AM
wingracer's Avatar
I believe it is OFNA/Picco 51613
wingracer is offline
Old 10-10-2010 | 10:47 AM
Ambros303's Avatar
Yup:
http://www.ofna.com/parts.php?start=4000
Scroll down till you get to the Picco Boost parts.
-51613 VENTURI 6MM CARB BLUE
-51614 VENTURI 7MM CARB BLUE
These are the Ofna partnumbers, dont know if Ofna uses different partnumbers for Picco parts...could be the Picco partnumbers are different.
Old 10-14-2010 | 07:51 AM
Lille-bror's Avatar
Gentlemen
One of the clubmembers runs Orion engines. Those venturies fits perfectly.
Cheers
Old 10-14-2010 | 09:20 AM
wingracer's Avatar
Gentlemen
Cheers
Just be careful of which Orion motor he is running. The old Orions were Piccos and should fit fine. Newer ones are not.
Old 10-15-2010 | 06:41 AM
Lille-bror's Avatar
Hi.
Yearh. Those venturies was from US Spec and Wasp models - the Picco based engine.
Thanks again, Wing
