Old 10-10-2010, 03:02 AM   #1
Lille-bror's Avatar
Default 6 mm venturi for NOSRAM/Orion/Picco engine
Hi.
I really need a 6 mm venturi for my NOSRAM engine. The engine (carburator) are similar to Picco Evo 2 turbo, LRP 21X, Orion CRF 21 and JPX21.
Here is the original NOSRAM 7 mm venturi:
As you can see, the NOSRAM venturi is different from Novarossi (yellow) venturies:
Will this fit my carburator?
http://www.amainhobbies.com/product_...1-60mm-Venturi
Thanks in advance, gentlemen
www.xray-shop.dk www.northtq.com
Best regards Bjarne Petersson, Denmark
XRAY / FX Racing Engines / OS Speed / HPI / Byron / HUDY / Proline / Sanwa MT4s / Sav÷x servos / Ultimate
I miss you Amy...
Lille-bror is offline   Reply With Quote
Old 10-10-2010, 05:16 AM   #2
Ambros303's Avatar
Originally Posted by Lille-bror View Post
Hi.
They might not fit as the old Orion engines were Picco based but the new Orion Alpha ones are Star / Sirio Based.
This one will probably fit, but it's 7mm:
http://www.amainhobbies.com/product_...tor-Insert-7mm
Not sure, but doesnt the Picco Boost have a 6mm venturi? That one might fit.
Edit: Just checked: the Picco Boost has a 6mm venturi.
Kyosho ST-RR Evo-ed // Sirio // Hitec // Sanwa
Kyosho MP9 TKI2 WC // Sirio // Savox // Sanwa
Ambros303 is offline   Reply With Quote
Old 10-10-2010, 07:21 AM   #3
Lille-bror's Avatar
Hi.
Thank you very much.
I've send the Scandinavian distributor of Picco engines an email
I miss you Amy...
Old 10-10-2010, 11:34 AM   #4
Lille-bror's Avatar
Did you find the partnumber?
I miss you Amy...
Old 10-10-2010, 11:45 AM   #5
wingracer's Avatar
Trader Rating: 24 (100%+)
I believe it is OFNA/Picco 51613
Sean. Certified speed crazed mowron.
Team Shepherd USA
www.ashfordhobby.com
wingracer is offline   Reply With Quote
Old 10-10-2010, 11:47 AM   #6
Ambros303's Avatar
Yup:
http://www.ofna.com/parts.php?start=4000
Scroll down till you get to the Picco Boost parts.
-51613 VENTURI 6MM CARB BLUE
-51614 VENTURI 7MM CARB BLUE
These are the Ofna partnumbers, dont know if Ofna uses different partnumbers for Picco parts...could be the Picco partnumbers are different.
Old 10-14-2010, 08:51 AM   #7
Lille-bror's Avatar
Gentlemen
One of the clubmembers runs Orion engines. Those venturies fits perfectly.
Cheers
I miss you Amy...
Old 10-14-2010, 10:20 AM   #8
wingracer's Avatar
Gentlemen
Cheers
Just be careful of which Orion motor he is running. The old Orions were Piccos and should fit fine. Newer ones are not.
Team Shepherd USA
Old 10-15-2010, 07:41 AM   #9
Lille-bror's Avatar
Hi.
Yearh. Those venturies was from US Spec and Wasp models - the Picco based engine.
Thanks again, Wing
I miss you Amy...
