8T 2.0
#9556
the ones i use r smaller, so there is room the the box. what i did is cut and air filter in half long ways and put it in the box to fill the space.
http://hobbycity.com/hobbycity/store...idProduct=6787
#9558
http://www.hobbypartz.com/83p-800mah-2s1p-74-15c.html
Started using these last summer. Ordered 5 of them just in case. They have slightly over an hour run time when you count warm up time before the race.
Before these batteries I kept trying to use LiPo's with 1500mah and 2000mah capacity, but they were dropping like flies. The off road use kept causing them to short out or just swell. So when I switched to the little batteries in the link above I could put more foam padding around them for more protection. And surprise...they come out looking new, work perfect, and no more battery failures.
#9559
Frank,
C rating should make no difference to the Rx. Voltage input is voltage input. The c rating on a lipo is basically its load rating. the higher the c rating the more load the pack can withstand.
That being said there is no standardized way of determining the C rating on a lipo. Each manufactor uses their own method so one company claims a 50c pack while if it were tested by a different company they may consider it 35c. C Rating is a bell and whistle, marketing tool...imo
#9560
#9561
Frank,
#9562
Found a couple good deals for 3X and 4X
4X
http://cgi.ebay.com/4x7-4v-900mah-15...item3f03315791
3X
http://cgi.ebay.com/3x7-4v-900mah-15...item4152e1560f
4X
3X
Looks like a great deal!! Do you use these? Would the plug on these work with spektrum receivers?
#9563
#9564
Hi all
A quick one. Do u use the manual specified method to bleed your shocks. That is install bladder with piston set at desired rebound, then cap. Or cap with bladder inside and bleed through the hole in the cap?
I saw a vid by Adam Drake and he was using the first method but he was also using foam compensators and drilled shock caps. Does it have to do with compensators, that he is using the bladder-first-method?
#9565
#9567
Hi all
#9569
Doesn't matter, My 900's are 15C and have never had an issue.
Yes ive used these for the past couple year's with great success, I think Ive tossed out 2 in total.
#9570
Hey guys I was wondering how you have your shocks threaded? I don't have a droop guage or ride height gauge so and I have the RTR 2.0 T. I havent touched the droop screws at all and I want to get the shocks set to Adam Drake's setup. I have had the shock set by eye but now I have a caliper and want to be more precise.
