Like Tree2991Likes
1/12 forum
Old 09-23-2010 | 04:53 PM
  #34606
Scottrik's Avatar
Originally Posted by CypressMidWest
6. Niftech (although your track will NEVER groove up and get great traction)
Why? Because it's not tracking greasy $hit all over your track. If you showed up at a "real" race with something on your tires (or anywhere else on or around your car) that got onto the track you'd be shown the door in a hurry.
But TOY car racers...
And using Niftech is such a pleasant experience compared to the others (ESPECIALLY Jack the Slimer)...daub it on, let the carrier evaporate off. No greasy, oily, nasty gooey tires to deal with, wipe, rub on your belly (yes, I've seen your shirts...) OR GET ALL OVER THE TRACK.
Scottrik is offline
Old 09-23-2010 | 05:25 PM
  #34607
hanulec's Avatar
gotta love how a discussion on traction compound brings out all of the 1/12th scale lovers.
Man, it'd be a shame for a car of that caliber to miss the US Indoor Champs.....
Ian - your promoting really hard man that you'll even take that messy ass wiring job at your race. i think you need to raise your standards
hanulec is offline
Old 09-23-2010 | 05:27 PM
  #34608
So what's White Jesus's opinion on compounds?
InspGadgt is offline
Old 09-23-2010 | 05:33 PM
  #34609
hanulec's Avatar
when i got back into racing my local track, 360 rc speedway - rip, used to run black can paragon. grip was always amazing. 360 closed... and now i run at horsham rc and last year we used jack until we couldn't buy it anymore and started using either SXT v3 or sticky fingers. if you're lucky enough to have a bunch of racers jack/sxt/sticky is fine, but if you have a smaller crew you NEED ground effects (and maybe some aspirin, or a stiff drink as that stuff just smells)
hanulec is offline
Old 09-23-2010 | 05:34 PM
  #34610
wingman2's Avatar
As far as the axle they are all pretty much the same...where I have problems is in what attaches to the axle like the hubs. Previous to my Copperhead I had to over tighten the IRS left side hub to keep it from slipping and as a result cracked 3 of them right where the screw head goes through. The IRS left side hub on my Copperhead has not had this issue. I think it has to do with it being re-annodized. It just seems to hold better without using a gorilla grip to tighten it. I rather like the angle of the slot on the CRC axle better because when you tighten it up the 2 sides meet more flush and will have less propensity to crack. However the one I had the wheel screw holes were all crooked (Probably just got one that slipped through inspection). But I wouldn't worry about that as all the ones I have seen on friends cars since then have been straight. My favorite left side hub though was the thread on one that AE used to use. Never had to worry about a balance issue and it never slipped on the axle. The problem though was in axle spacing...there was pretty much only 1 width you could run with it. I also heard some people had issues with the threaded part coming out of the axle.
Hi mate, I have used several differant 'US' type axles, and found by putting a very small spacer, or washer on the hub that clamps onto the axle, you can do the screw up tight enough so that it does not slip on the axle, but no so tight that it puts excessive force onto the axle itself. The spacer/washer goes on the threaded part of the screw between the two halves that clamp together once you have tightened the screw. Hope that makes sense. I would also say that my favorite axle is the Corally axle that takes the Corally type wheels. The design is really superb, but it will only fit on Corally chassis's of course.
wingman2 is offline
Old 09-23-2010 | 05:40 PM
  #34611
hanulec's Avatar
the more i think about it.. i actually think rubber TC is more effected by traction compounds (and track conditions) than pan cars with good tires (i.e. 1/12th... and not hard spec wgt tires). prior to vegas i practiced at a big but dirty track. my 1/12th scale felt great there although it was sprung really heavy.. such that i could of never driven it like that at IIC. on the other had my touring cars were complete piles spinning out under acceleration.
hanulec is offline
Old 09-23-2010 | 06:00 PM
  #34612
Yeah I was thinking on doing that...but all of my screw on type axles have a flange that the gear rides on instead of using a bearing so it isn't as smooth. May be something I look at again in the future.
Old 09-23-2010 | 07:41 PM
  #34613
odpurple's Avatar
Originally Posted by JayBee
Was that a shorter axle? The name Niftech sounds familiar. I believe thats what I was told it is
BTW....whats the part# of the best axle with no comparison?
Nope, that is not a Niftech axle. I'm positive that is a Japanese axle and I'm pretty sure it's a Kawada. Niftech stuff is made here in the USA.
The Niftech part # for their hollow axle is 1005, the diff hub is #1011 (disclaimer: the Niftech catalog is confusing so no guarantee on the #s). Their left side hub is a thing of beauty but pretty bulky. It also used to be too wide but with brushless motor pods moved to the right it will probably work. I just use an IRS left hub.
The Niftech diff is pinned for their "Rocket" diff rings, D rings won't fit. So when you've bought the whole deal the cost is over $100.00, but IMO well worth it
odpurple is offline
Old 09-23-2010 | 07:47 PM
  #34614
superspeed's Avatar
Have you seen Niftech's website? I don't think it has been updated recently. The product lineup is out dated.
http://niftech.com/
superspeed is offline
Old 09-23-2010 | 09:30 PM
  #34615
CypressMidWest's Avatar
Originally Posted by Scottrik
And using Niftech is such a pleasant experience compared to the others.
Aside from the LACK OF TRACTION I'd agree. We actually race toy cars, so we use what toy car racers use.
CypressMidWest is offline
Old 09-23-2010 | 09:38 PM
  #34616
I just like having Nash to kick around at races. Maybe it would be a good idea to enter myself, even though I'm not racing, so he could actually finish ahead of me...... j/k Dirla.......
Old 09-23-2010 | 10:24 PM
  #34617
Scottrik's Avatar
Go figure...works great for me and several folks here. On our track about 2/3-3/4 have been running Niftech for about 3 years now, the rest generally use Jack.
Something we did for our 2-day race last spring was put some Jack in a spray bottle and spray a little down in a strip on the straight on Friday when the track was completed. This tracked around and the track grooved in very nicely. No one, even the out-of-towners who often complained about the traction, had a lack of grip.
Scottrik is offline
Old 09-23-2010 | 10:28 PM
  #34618
We used it as the "SPEC" traction at WOH in Cincy for a season, the track never had any bite. Switched to Paragon and magically our testing became relevant for big races. I actually love Niftech on top of a Paragon groove. It can free-up a car that's too tight. But when used exclusively, we found it wasn't enough. Maybe our turnout was too low.......
Old 09-23-2010 | 10:34 PM
  #34619
wingracer's Avatar
Refresh my memory, what were they using at the worlds? This first stuff didn't groove up at all and the second stuff grooved up almost instantly.
wingracer is offline
Old 09-24-2010 | 08:52 AM
  #34620
Hi guys
I am new to 1/12th scale , i have just bough my 1st a Corally 12SL
i plan to use my Tekin RS speedo and a 13.5 motor , but how do i go about boosting my Lipo voltage from 3.7v to the needed voltage for the servo and reciever ???
also how bigger lipo will i need ?? 5000 or bigger ??
Thanks Phil
sidecarphil1 is offline
