losi 350, what is ur best fuel mileage? >
Old 10-10-2010 | 06:16 AM
  #16
UltegraSTI's Avatar
My 350 is at around 1.25gal and on a short loose track and turbo head (re10 pipe and 97T plug) in a 8B2.0 gets 7m safe thats it. last race of the yr my driver (who i was helpin out after a rough yr) was runnin 2nd just a straight behind after some mistakes late in run (now i wish they didnt cut race down to 15min heh) and i made call just run it if we run out well so what last race of yr-but at this pt if we pit we lose. leader did manage to make it on fuel (different motor pitted 1 lap later). we stopped at 7m mark not knowin how much fuel was wasted during grid. so we tried to go 8m+ on 2nd tank shot it in there very full (as we could get it). out fast. but he crossed the line the master clock ran out and so did he. just under 1lap short. oh well.
thought bout puttin stock pipe back on to see if it'd be better. that or a re11 which should be better w/o question.
R
UltegraSTI is offline
Old 10-14-2010 | 06:15 PM
  #17
chedda bob's Avatar
From: Where the ego's are so big, people's heads can't fit in the door
Just fired up my new 350 for the first time, going to break it in fully w/ the stock non turbo head. I will be going turbo head here in a week or so. My question is how many shims to I put in? What plug is the best for economy/power? I have already read that the pipe of choice seems to be the re11? I'm looking for 10 min at the min. for mileage... If I can't hit that mark I might as well hang it up around my local tracks
Thanks guys!
BTW~ Before I even fired it I put new ceramics in it, as well as knife edged the rod @ work... Fired first try and perfect idle for the entire 1st tank, not even a hiccup!
chedda bob is offline
Old 11-08-2010 | 09:17 PM
  #18
Even though I’m getting good run time with stock head what happens fitting a turbo head,most report more power but what happens to run time.
Is it better,same or worse.
It worries me that I gain the extra power and chew up more fuel.
RustyOne is offline
Old 11-08-2010 | 09:27 PM
  #19
trx-1racer's Avatar
I live in Team Losi driver land... I built my 350 exactly the way they recommended and the motor comes to life...
Use the Turbo head conversion, the instructions tell you which shims to use and add the RE11 pipe. I read plenty here that say no to the RE11, but when one of the team drivers is waiting for a new Novarossi, thats what they run and it flies. I get right on 10 minutes... which means I pit at 9 mins comfortably.
Even 10 is short around here... Kinwald goes 15 without any trouble with his Novarossi.
trx-1racer is offline
Old 11-08-2010 | 09:28 PM
  #20
little extra power with maybe 30 to 40 seconds better run time, honestly i went back to standard plug and just found right pipe and clutch set-up and got the same as turbo plug, plus the OS#8 and mc59 standard plugs are much cheaper
inferno13 is offline
Old 11-09-2010 | 01:52 AM
  #21
I just purchased 6 O.S. turbo plugs @ $7ea delivered.i didn’t think that was too bad a deal.
RustyOne is offline
Old 02-17-2011 | 10:16 PM
  #22
endy0430's Avatar
I have a Losi 350 and wanted to know what is a good clutch for this engine and also I'm getting the turbo head upgrade and what pipe would you guys recommend I get...Thanks
endy0430 is offline
Old 02-18-2011 | 03:07 AM
  #23
The stock losi one’s work ok but the shoes wear out to quick.
Install the hard wearing dynamite shoes and it will give you all the options you need for different tracks
RustyOne is offline
Old 02-18-2011 | 04:57 AM
  #24
endy0430's Avatar
what do you think of this one..
http://www.amainhobbies.com/product_...-Clutch-System
endy0430 is offline
Old 02-18-2011 | 05:32 AM
  #25
Yes the werks has had good positive feedback and so has the Ascendancy Racing Effortless Racing Clutch Kit (34mm)
http://www.amainhobbies.com/product_...lutch-Kit-34mm
You can use the losi clutch with these shoes
Dynamite Max-Life 8ight Aluminum Clutch Shoes Set
http://www.amainhobbies.com/product_...ch-Shoes-Set-4
RustyOne is offline
Old 02-18-2011 | 06:24 AM
  #26
endy0430's Avatar
I was looking also at the Ascendancy but Amain is out of stock so decided on the Werks .. Hey one more question what do you think of this pipe for the 350
http://www.amainhobbies.com/product_...-System-T-2050
endy0430 is offline
Old 02-18-2011 | 07:34 AM
  #27
Smile
After about the 3rd gallon I was getting about 12min run times with the re-11 pipe,no turbo just stock,using byrons 30% with 2 med aluminum and 3 carbon shoes on clutch last year.
The fisherman is offline
