The Speed Passion Thread >
Like Tree57Likes
Old 09-05-2010 | 09:00 PM
  #5521
irgo's Avatar
Default SP GT 2 DMTS UPDATES
there is something wrong with the dmts on
firmware that i detect,
old stock firmware and the stock sc firmware.
Since the stock sc(super charge) firmware is based on first stock firmware.
And this is what i found
as i turned off the supercharge, and works with dmts only,
it just can't beat the super stock brushed
with gt7 , with equal motor turn.
With same timing and fdr, the dmts will just fail and loosing alot of max torque, no matte we max out the drrs to level 9.
And we found the reason,...
It's because DMTS is working with DRRS throught throotle,
and don't have start rpm.
It change the timing too early there, when throtle is just at about 50
what speed passion have to do is
add start rpm on DMTS
and let the timing at zero until the edge rpm reach.
SP GT2 must have
2 start rpm:
1.DMTS RPM START
2.SC RPM START
the result will be a better cornering!
We need comment about this.
irgo is offline
Old 09-06-2010 | 07:28 AM
  #5522
Originally Posted by tc3 racer sc
i guess no help on my question can any one help
You need to use the setup completely. With the same FDR also.
On another note. I've tried to attach my set sheets and it tells me they are to large. How do you down size them?
SRW141 is offline
Old 09-06-2010 | 08:02 AM
  #5523
kschu's Avatar
anyone need a LCD USB Professional Programmer??
kschu is offline
Old 09-06-2010 | 08:48 PM
  #5524
tc3 racer sc's Avatar
email it to me [email protected]
tc3 racer sc is offline
Old 09-07-2010 | 01:47 PM
  #5525
Hey guys, when adjusting the timing on a V3.0 Competition 17.5 brushless, should the timing/sensor be able to move without loosening the can bolts. Mine can be pushed either direction when the bolts are still tight? Is this normal.
Secondly, what timing level, 0-10, do you guys recommend (I'll keep an eye on temps) for an SC10 on a fairly tight track? I'm running a Associated SXX-Competition ESC; should I leave the timing on the motor alona an just use my ESC? What settings/power levels do you run on your ESC?
Thanks!
BestNThDez is offline
Old 09-07-2010 | 02:54 PM
  #5526
@Speed Passion
Any new firmware due for release soon?
528_Stock has been out a fair while now, maybe you guys have had some more time to play with it to squeeze out a little more performance?
or are you waiting for the competition to take the advantage?
geubes is offline
Old 09-07-2010 | 09:17 PM
  #5527
Originally Posted by geubes
@Speed Passion
New software (stock and modified) testing @ TITC the last couple of weeks. They have to make sure the new software won't burn motors within minute before releasing....stay tune.
Solara is offline
Old 09-07-2010 | 09:28 PM
  #5528
defcone's Avatar
Wasn't TITC ages ago?
defcone is offline
Old 09-07-2010 | 11:11 PM
  #5529
skypilot's Avatar
just so were all clear on the question...charlie gave you a setup, but you decided to not run the gearing for that setup, and your wondering why your car faded and the motor got hot. Is that the question?
skypilot is offline
Old 09-08-2010 | 02:28 AM
  #5530
irgo's Avatar
willson said this month.
irgo is offline
Old 09-08-2010 | 02:33 AM
  #5531
Me_MrTyson's Avatar
Is this update more a refind of current software or a complete new setup?
Me_MrTyson is offline
Old 09-08-2010 | 03:18 AM
  #5532
charlie_b's Avatar
Super Moderator
You know, i did about 90-95% of the testing for the 100422 and 100528 for Speedpassion on a Cyclone. What magic answer are you looking for? You didn't even try everything i suggested.....
charlie_b is offline
Old 09-08-2010 | 03:23 AM
  #5533
Azr's Avatar
Azr
Originally Posted by kschu
Is it compatible with the 1st version ESC?
Azr is offline
Old 09-08-2010 | 05:24 AM
  #5534
Default 7.5T
I'm running a photon with a 7.5T on a medium sized outdoor track with a straight of about 30 meters.
What software (and settings), and FDR do you guys recommend?
help appreciated.
Sam
sammies is offline
Old 09-08-2010 | 07:43 AM
  #5535
Marcos.J's Avatar
Super Moderator
Solara are you in charge of the Speedpassion website? If so can you make sure that my set up is posted along with Harolds?? mine is posted on here but I can send you a copy if you need it.
Marcos.J is offline
