RC10B4.1 FT/WC
Old 08-01-2010 | 06:45 PM
  #46
what is the difference between these and the regualr ft kits?
bbrace3m is offline
Old 08-01-2010 | 06:48 PM
  #47
RA99GT's Avatar
the .1's have all the latest parts
RA99GT is offline
Old 08-01-2010 | 07:00 PM
  #48
whats all the latest parts?
bbrace3m is offline
Old 08-01-2010 | 07:27 PM
  #49
mxracer458's Avatar
on the front wheels,in the manual it says the lock nut on the front axle is 4-40 5/40, so if im buying some new lock nuts what size is it actually 5/40?
mxracer458 is offline
Old 08-01-2010 | 08:38 PM
  #50
kyle3333's Avatar
http://67.199.85.166/ae/b4.1/b4.1_home.php
kyle3333 is offline
Old 08-01-2010 | 10:08 PM
  #51
aeRayls's Avatar
You can get the all plastic black nuts which will fit either 4-40/5-40. If you get the steel or alum locknuts the thread pitch is 5-40. Get the nuts ae uses for the slipper, Ive used these since day 1 in '03. The all plastic nuts can wear out and be pulled off the axle.
aeRayls is offline
Old 08-02-2010 | 01:33 AM
  #52
mharlow's Avatar
Originally Posted by 4times
Finally...they come with yellow wheels!
They may as well give them away because no one wants to buy them.
Everyone knows that white wheels are faster than yellow.
mharlow is offline
Old 08-02-2010 | 02:31 AM
  #53
mjk1210's Avatar
The exception to the rule being if your initials are "RC", of course.
mjk1210 is offline
Old 08-02-2010 | 07:09 AM
  #54
Bobby Z's Avatar
Does it count that my initials are RC? First and middle name though and I think you are referring to someone else with first and last name!! LOL
I prefer white wheels anyway these days. Years ago when I was running Losi buggies I always used yellow wheels. I think nearly everyone did back then.
Bobby Z is offline
Old 08-02-2010 | 07:26 AM
  #55
Ray Charles? What difference would it make? He was blind..
Serzoni is offline
Old 08-02-2010 | 09:42 AM
  #56
mjk1210's Avatar
mjk1210 is offline
Old 08-02-2010 | 06:51 PM
  #57
Can someone explain the difference in using the new arm mount set and using the new rear hub's to change toe in
X God is offline
Old 08-02-2010 | 08:48 PM
  #58
Changing the toe block changes the inboard toe. Increasing inboard toe in general provides more overall traction and makes the car more mechanically stiff. The downside of inboard toe is it can decrease cornerspeed.
Changing the outboard toe (hub carriers) is generally a mechanically softer change, and would be better suited for lots of sweeping corners. It also feels like a more subtle change.
The toe blocks also change the wheelbase of the car more than the hubs.
DanGriffin is offline
Old 08-04-2010 | 11:41 AM
  #59
F18engineguy's Avatar
Does anyone have this car yet?
F18engineguy is offline
Old 08-04-2010 | 11:51 AM
  #60
RA99GT's Avatar
i got one today!
RA99GT is offline
