Like Tree2Likes
RB Concept Engine Thread..
Old 07-14-2010 | 12:20 PM
  #1321
Maximo's Avatar
Originally Posted by BMXNBULLDOG
So Chris being in Colorado and I'm from Colorado, Denver area, and not finding the 2045 pipe setup in the budget, would you suggest the next best choice is the RE10? This is for the Killer 10. Is the 086 pipe a choice also? Or which of the 2 would you go with? Also what glow plug are you recommending? I'll be running 30% Byrons fuel. Any help greatly appreciated, Thanks.
on K10 the JP3 will blow the doors off a 2045..... Best pipe for that engine is a JP3
Maximo is offline
Old 07-14-2010 | 12:36 PM
  #1322
Default PIPE
How about the JP-1? Already have one of those. Or do i need to step to the JP-3?
BMXNBULLDOG is offline
Old 07-14-2010 | 12:54 PM
  #1323
orracle's Avatar
Default WS7II
Any one got tuning tips? Running a WS7II with TNT Mods, Axe Rossi 2050 pipe and Byrons 30%. Any info will help.
orracle is offline
Old 07-14-2010 | 03:15 PM
  #1324
Chris Peralta's Avatar
Hey man, I am actually in Longmont as well. I have never ran a K9 or a K10 so I would listen to Maximo on this as he has modded and worked with a lot of them. Try your JP1 and see how you like it, since we are at such a high altitude the JP1 may give you some extra grunt you loose from the altitude.
Chris Peralta is offline
Old 07-14-2010 | 03:19 PM
  #1325
The biggest thing I can suggest is possibly changing the gearing on the car. The WS7 is a top end motor and will feel like it lacks bottom end in many applications. I have used a stock WS7 and it was great but I changed the gearing from a 48 tooth spur to a 50 tooth as the two teeth on the spur is less dramatic than one tooth on the CB.
Other than that just tune the engine like normal, make sure it sings real good down the straight away, then tune the LSN so the car accelerates real well and can sit and idle for 3 or 4 seconds without loading up.
Old 07-14-2010 | 05:29 PM
  #1326
aznitronut's Avatar
That pipe your using isn't the best pipe for that engine, go with the RB 2045/192 header if you can, I have the the Nova Rossi 9886 pipe on that engine to, it works well, but not like the 2045.
aznitronut is offline
Old 07-18-2010 | 10:18 PM
  #1327
Originally Posted by Chris Peralta
The only standard OS plug that is the same is the LC3 Hot plug. OS plugs are short body plugs, they will work but you might be chasing the tune all day long. If you can't get RB or Novarossi plugs get an odonnell or a mccoy and you will be fine.
Just letting you know those RB plugs just came in from A main and yes i can see what you were saying about being longer in the body..
Now i might be able to get a tune from it.
RustyOne is offline
Old 07-19-2010 | 07:18 AM
  #1328
That should help ya out a lot!!
Old 07-25-2010 | 03:47 PM
  #1329
Hello engine gurus - I need some help
I have a new (1.5 gallons) Killer 9 and I can't get it tuned, I have tried everything. It will not idle properly, it always sounds too rich on the bottem (revs real high then drops off). I can lean it out on the bottem to get it to idle better but then it starts to lean bog on acceleration this is usually at 1 to 1.5 turns out. I tried backing everything to factory settings and starting over but then it is so rich it will not even start.
I am running a novarossi 5 plug and 25% byrons and I am at my witts end. I figure it is probably a carb defect but wanted to know if anyone else had any ideas.
kjam is offline
Old 07-25-2010 | 03:53 PM
  #1330
tc5 man's Avatar
Tech Prophet
thats the same problem im, having no matter what i do i cant get the bottom end to get leaner i even turned the idle up to stop the engine from loading up at idle. and i turned the low end about 1/2 turn and more same thing.
and it will flame out too because of it on the track.
i think its just because its, still new and im almost throw a gallon.
im running ebmods 20 % with a #100 odonnell plug.
im running the rb s5 engine.
tc5 man is offline
Old 07-25-2010 | 03:57 PM
  #1331
diamondracing's Avatar
Word of advice the rubber o ring on the carb take that off and put on http://www.amainhobbies.com/product_...or-Base-O-Ring That will help alot that stock o ring is terrible and not novarossi - rb quality. My K9 runs like a bat out of hell with a little over a gallon
diamondracing is offline
Old 07-25-2010 | 03:59 PM
  #1332
tc5 man's Avatar
Tech Prophet
really thanks is that the reason why its doing that ?
il try out that o-ring
tc5 man is offline
Old 07-25-2010 | 04:01 PM
  #1333
I had the same problem. I usually run the B10 -B9 more expensive engines and was getting real Soon as I changed that o ring it ran like a champ. I also use 97t odonnell plug
Old 07-25-2010 | 04:06 PM
  #1334
tc5 man's Avatar
Tech Prophet
i knew something was wrong , i never had a problem with my nova .21 bf with tuning the low end even at a half gallon or more.
i do have some nova carb o-rings will they fit ? does the stock ones on the rb swell up or something.
tc5 man is offline
Old 07-25-2010 | 04:12 PM
  #1335
The K9 is real thin and worthless IMO your 21bf should be thicker and hold a seal better.
