Losi 1/8 8ight E 4wd Thread >
Old 07-08-2010, 08:01 PM
  #4726
Hate2Looz's Avatar
Trader Rating: 27 (97%+)
Originally Posted by Casper
I have not heard of 2.0 arms bending? I know this was a typical issue with the 1.0's.
My 2 month old 2.0 arms are all bowing/twisting just like 8ight arms are known for. The front suspension design forces the arm to bend so its gonna happen. I'm fine with it and just replace them when they get too far out of shape.
Hate2Looz is offline
Old 07-11-2010, 07:20 PM
  #4727
Guest
Danger it boy!!!
LOSIRACER77 is offline
Old 07-12-2010, 12:03 AM
  #4728
-WHEELMAN-'s Avatar
Trader Rating: 267 (98%+)
Ready for the shootout!! Completly rebuilt after seven days of club racing and a Jimmy Babcock round of neglect. Thought id show it off while it's clean. By the way paint was by DGDesigns if anybody is in the market search him he's an amazing guy with talent and a SoCal local.
-WHEELMAN- is offline
Old 07-12-2010, 04:47 AM
  #4729
Jube's Avatar
Trader Rating: 43 (100%+)
Nice ride Wheelman!
Jube is offline
Old 07-12-2010, 07:50 AM
  #4730
Nice Car!!! Do you run the body clips? or just let the velcro hold the body?
Lon_L is offline
Old 07-12-2010, 04:55 PM
  #4731
Integra's Avatar
Originally Posted by dangerwr
Nothing that I recall for the front--I believe they are the same P/N (if not the change is minor). The rear I remember different Outer hinge pins or something. Please somebody correct me if I am wrong . . .
Correct...you need the 3.5mm pins for the rear arms and also the rear hubs or you can drill your stock one's.
Nice Ride -WHEELMAN-
Integra is offline
Old 07-12-2010, 08:13 PM
  #4732
wheelman, that looks awesome! what batteries are you running to run the bulldog body?
Also, anyone with a converted 8ight-t-e, what bodies work, any of the normal 8ight-t boddies?
theagentorange is offline
Old 07-12-2010, 08:45 PM
  #4733
Integra's Avatar
what exactly do you mean ?
Integra is offline
Old 07-12-2010, 09:16 PM
  #4734
Jube's Avatar
Truggy bodies have plenty of room for just about anything you want to do.
Jube is offline
Old 07-12-2010, 09:27 PM
  #4735
dangerwr's Avatar
Default New spacers in shock rebuild kit?
All,
Losi has supplied some different washers in the plastics (pistons, spacers, etc.) for rebuild and have been told to use one of the new thin washers per shock between the 2 o-rings. Now this would make the entire "stack" a bit shorter.
Has anyone have any experience with this??
dangerwr is offline
Old 07-12-2010, 10:41 PM
  #4736
zrxrxr's Avatar
Where do you get those captured ball studs for the steering turnbuckles? The ones on my 8ight 1.0 aren't captured and they tend to pop out after a little knock. Thanks
zrxrxr is offline
Old 07-12-2010, 11:12 PM
  #4737
dangerwr's Avatar
They are just screws and are from the 2.0 kit.
dangerwr is offline
Old 07-13-2010, 06:25 AM
  #4738
brofroe's Avatar
Trader Rating: 20 (100%+)
Just put a washer on top of the ball before you put the screw in. Thats what I have on my 1.0. Works fine. Will bind a little at full droop, just bend the edge up a little to clear the tie rod end if it binds.
brofroe is offline
Old 07-13-2010, 07:19 AM
  #4739
Integra's Avatar
the 1.0 balls will NOT allow a washer prior to going through the ball as the Ball Is the screw....you need the 2.0 balls and a flat head to make it pop proof.
Integra is offline
Old 07-13-2010, 07:29 AM
  #4740
Trader Rating: 16 (94%+)
Default 8ight-E 2.0: Opinions
What is everyone's opinion on the Losi 8ight-E 2.0 vs the Assoc RC8Be?
Since you can only buy the 8ight-E 2.0 with the electronics, what is everyone's opinion on that too? Would you go racing with the Losi electronics and expect them to last 6+ months, or would you yank them out and sell as new, and then buy new electronics?
kn7671 is offline
