8T 2.0
Old 06-29-2010 | 06:17 AM
  #7951
Originally Posted by GMS_Racing
Same thing happened to me with the Losi quick change mount on the Losi box. I went back to the stock mount and it was fine. Easier to start and a lower center of gravity cant hurt
i had the same issue also...I love having the quick change on there...so I just made the flywheel opening a little bit longer on both sides. I believe there are a couple of people who have take a mm or 2 off off the top section of the quick change....havent seen it in person though.
Fabtech813 is offline
Old 06-29-2010 | 07:13 AM
  #7952
2tap's Avatar
when i got my blue box i saw the wheel wasn't as high as the losi one so i put washers under the the motor/wheel mount before i ever used it.
think i had to use slightly longer screws.
flywheel opening does NOT need to be modded.
also using losi q change.
works fine.
Originally Posted by tropy
quick question has anyone had this problem I start my truggy with the ofna truggy box (blue one) and I put the losi quick change mount and the rubber wheel from the box doesnt reach the flywheel (losi) but when I put my old kinghead mount it does. any one else had this?
2tap is offline
Old 06-29-2010 | 08:15 AM
  #7953
Arco's Avatar
Originally Posted by Toiffel
+1
+2
Arco is offline
Old 06-29-2010 | 09:41 AM
  #7954
token's Avatar
make sure the pices that attach to the engine is the right way. I can use my quick change on any starter box set up for a losi, no problem. make sure they are on correctly.
token is offline
Old 06-29-2010 | 11:25 AM
  #7955
deadmancourt's Avatar
+1
+2...sounds like you need a new starter wheel,maybe its a little worn down
deadmancourt is offline
Old 06-29-2010 | 11:50 AM
  #7956
Originally Posted by deadmancourt
ok here is another question...what does moving the shock position on the towers and arms do?....if i go in on the tower,do i have to go out on the arm?...and visa versa?....what does this help? when the shocks are laid out what does that do?....when the shocks are more straight up and down,what does that do?...im trying to get my truck dialed and this is 1 of the most confusing things for me
anyone?
Old 06-29-2010 | 12:00 PM
  #7957
JAMMINKRAZY's Avatar
anyone?
Read the setup section at the back of your manual. It has a lot of good explanations about shock positions and angles.
JAMMINKRAZY is offline
Old 06-29-2010 | 05:38 PM
  #7958
Hate2Looz's Avatar
Originally Posted by Andy Z
I run the same box with no issues with my quick change engine mount (Losi)
No issues here with the same setup. It's a tight fit but I am picky about my bump box lining up good so I do spend some extra time getting it dialed in.
Hate2Looz is offline
Old 07-01-2010 | 03:37 PM
  #7959
Frank L's Avatar
anyone?
Here you go man right from the hudy setup guide. BTW send me a PM and an email and Ill send you the setup guide in PDF
SHOCK UPPER POSITION (SHOCK TOWER)
Front Shock Tower
Outer holes
• Faster steering
• Better on bumps and jumps
Inner holes
• Easier to drive
• More side bite
• Slower initial steering
Rear Shock Tower
Outer holes
• Less mid corner grip
• More traction into corner
• Squares up better on exit
Inner holes
• More steering into corner
• More mid corner grip
SHOCK LOWER POSITION (ARM)
Front Arm
Outer holes
• Increases stability
• Easier to drive
• Bigger turn radius
Inner holes
• Faster steering
• Better for bumps and jumps
Rear Arm
Outer holes
• More stability
• More lateral grip in turns
Inner holes
• Less side bite
• More exit traction
Frank L is offline
Old 07-02-2010 | 09:26 AM
  #7960
offroad racer's Avatar
Default I NEED ANSWERS ASAP
Hey guys,
I was working on switching out my front diff case for a new one when I stripped the set screw holding that cup to the gear inside the case. I need to get it off but I can't. how do I get it off?
I need answers asap
thanks in advance
offroad racer
offroad racer is offline
Old 07-02-2010 | 09:39 AM
  #7961
Frank L's Avatar
Originally Posted by offroad racer
Hey guys,
I need answers asap
thanks in advance
offroad racer
You can slot it but that will cause the ring gear to be unbalanced. The only way I can think of is to drill it out or use a very very tiny easyout. I think either way the diff case and or ring gear will be toast. Good luck
Frank L is offline
Old 07-02-2010 | 09:40 AM
  #7962
thanks
Old 07-02-2010 | 04:01 PM
  #7963
Muggydude's Avatar
I had this issue a while ago, I use the losi quick change mount and the ofna truggy box. Here's what I found: Make sure that you have aligned the pegs perfectly with the chassis hole. (I had to use the extra large black plastic plate on top with multiple rows) Next, and most importantly I have found, you must push down on the engine head, not the body or shock tower. Made all the difference for me. Mine now works with a well worn wheel.
Muggydude is offline
Old 07-02-2010 | 10:15 PM
  #7964
builtb16a's Avatar
ive had to push on the head, and not the body since day 1.
i have a roller and a red RTR box. too much flex in the chassis to just push down on the hood and the wing.
i really wish i could get a new bump wheel.. amain/horizon has had that damn wheel back ordered for a good 3 months now.
builtb16a is offline
Old 07-03-2010 | 08:14 AM
  #7965
Gearhead racer's Avatar
Will the blue box work with the roller without modding the chasis? Running the regular motor mount and losi flywheel that came with it.
Gearhead racer is offline
