Novak Ballistic Problem >
Old 06-30-2010 | 04:43 PM
sidewayzsc300's Avatar
Unhappy Novak Ballistic Problem
Having a problem with my ballistic set up. 8.5T motor and running a 5000mah 2c lipo. Freshly charged lipo put in tc5 and runs for about 5-10 mins and then the esc led starts flashing. First the red and amber together twice and then it scrolls through all leds. Help??????
sidewayzsc300 is offline
Old 06-30-2010 | 04:55 PM
sounds like the BEC is overloading because if i recall those blinkers are the reboot from a shutdown/thermal. if this is the case get a voltage regulator , spektrum makes one "spm1600"
Eric From Vegas
Hyjaxx is offline
Old 06-30-2010 | 05:04 PM
my buddy is running the same setup but with a 4500mah lipo with now problems. Is this happening cuz im running a larger lipo?
Old 06-30-2010 | 06:24 PM
if its a thermal issue ,perhaps. but if its the BEC/low voltage issue then i wouldnt think so
Hyjaxx is offline
Old 06-30-2010 | 09:13 PM
its a temp issue with esc i think cuz i let it sit for a couple minutes and i have full function agian. Im using car for drifting, does anyone know what gears i should run, spur/pinion set up
Old 07-01-2010 | 07:43 AM
Company Representative
Because I am not part of Novak's technical support group, I suggest you email [email protected] with your question, Our regular CS/Tech Support hours can be located here. Before emailing, take a moment to review the instructions (trouble-shooting guide) originally included with your Novak Item:
Novak Instruction Downloads
Trouble-shooting TeamNovak's One Touch™ Speed Controls
Please make your initial email as detailed as possible. Include:
~ speed control (brand/model)
~ motor (brand/wind)
~ number/type of cells
~ battery, brand (c rating/capacity
~ rotor (old/new)
~ connectors used
~ servo (brand/model)
~ radio system (receiver/transmitter)
~ vehicle & gearing
~ warranty claim?
~ lipo cut-off, on/off
~ any external modules (BEC/brand, Glitch Buster)
~ other important info: water damage, corrosive chemical sprays, excess heat, etc
The more information you provide in your first email, the more quickly tech support can offer you assistance.
NovakTwo is offline
Old 07-01-2010 | 01:09 PM
subiefreak86's Avatar
hey scott i run a 5300 20c , my girl runs the 4200 not that it matters in this cituation
subiefreak86 is offline
Old 07-02-2010 | 02:11 PM
So i called novak today and they said that is may because im running a 20c 5000mah lipo. Who else is running this motor set up and what are they running for lipos??????
