-   -   Novak Ballistic Problem (https://www.rctech.net/forum/radio-electronics/412766-novak-ballistic-problem.html)
sidewayzsc300 06-30-2010 04:43 PM
Having a problem with my ballistic set up. 8.5T motor and running a 5000mah 2c lipo. Freshly charged lipo put in tc5 and runs for about 5-10 mins and then the esc led starts flashing. First the red and amber together twice and then it scrolls through all leds. Help??????
Hyjaxx 06-30-2010 04:55 PM
sounds like the BEC is overloading because if i recall those blinkers are the reboot from a shutdown/thermal. if this is the case get a voltage regulator , spektrum makes one "spm1600"
Eric From Vegas
sidewayzsc300 06-30-2010 05:04 PM
my buddy is running the same setup but with a 4500mah lipo with now problems. Is this happening cuz im running a larger lipo?
Hyjaxx 06-30-2010 06:24 PM
if its a thermal issue ,perhaps. but if its the BEC/low voltage issue then i wouldnt think so
sidewayzsc300 06-30-2010 09:13 PM
its a temp issue with esc i think cuz i let it sit for a couple minutes and i have full function agian. Im using car for drifting, does anyone know what gears i should run, spur/pinion set up
NovakTwo 07-01-2010 07:43 AM
Because I am not part of Novak's technical support group, I suggest you email [email protected] with your question, Our regular CS/Tech Support hours can be located here. Before emailing, take a moment to review the instructions (trouble-shooting guide) originally included with your Novak Item:
Novak Instruction Downloads
Trouble-shooting TeamNovak's One Touch™ Speed Controls
Please make your initial email as detailed as possible. Include:
~ speed control (brand/model)
~ motor (brand/wind)
~ number/type of cells
~ battery, brand (c rating/capacity
~ rotor (old/new)
~ connectors used
~ servo (brand/model)
~ radio system (receiver/transmitter)
~ vehicle & gearing
~ warranty claim?
~ lipo cut-off, on/off
~ any external modules (BEC/brand, Glitch Buster)
~ other important info: water damage, corrosive chemical sprays, excess heat, etc
The more information you provide in your first email, the more quickly tech support can offer you assistance.
subiefreak86 07-01-2010 01:09 PM
hey scott i run a 5300 20c , my girl runs the 4200 not that it matters in this cituation
sidewayzsc300 07-02-2010 02:11 PM
So i called novak today and they said that is may because im running a 20c 5000mah lipo. Who else is running this motor set up and what are they running for lipos??????
