Nomadio React
#16
ebay is the best place I have found
#18
There was a guy on the Nomadio forum that was putting together a group buy for temp sensors. He evidenty was savvy enough with electronics to locate some suppliers to build some sensors. I was down to buy three temp sensors from him as were several others. Unfortunately, the forum website was pulled before he could get the sensors produce and everybody lost contact with him,
. I think I have a couple of the voltage sensors and speed sensors that I dont use that I would be willing to sell for a song or trade for some new temp sensors. The on board temp sensor is just fantastic and beats the sox off of using a temp gun.
#20
I am technically savvy myself and found some schematics awaiting parts to arrive and will construct the temp sensors - if they will work I will post about the tempreture sensors I made them without any issues and they work great
PT 1000 are used as tempreture sensors
#23
the problem is that if a capacitor blew definetly there was a voltage issue ie the regulator failed this could have happened if you were using a battery pack other than nomadio specified - the transmitter i bought gave me a 6v pack altough the transmitter works well it surely stress it out the main regulator
Bernard
Bernard
#24
#25
wow, the transmitter battery is big enough to last a month i bet.? seriously is that a real video. you should always mount your rec on some sort of cushion. i just use puffy tape. (can't think of the real name)
#27
Yes it is.
If anyone wants to they can run a bec with a lipo as well. I have done this for the last few years and it works great. I had to dremel some of the plastic in the battery tray, but easy job. I went a step further recently and hard wired the regulator into an empty space in the handle of the radio. No more pluggin and unplugging the bec
#28
has any one had the problem with their react where the led on the transceiver blinks and the transmitter isn't controlling it. do i need a new transceiver? i would get one from a-main while they're still available as i love this radio. i just put a life batt in the transmitter and it works great but now i'm having this problem ..
#29
bump, anyone,,,anyone. it won't rebind and the led on the trans. seems to be a code by the way it blinks, but nothing in the manual discusses this. i have anew trans on the way, hopefully that fixes my problem..
