8T 2.0
Old 06-16-2010 | 08:33 PM
  #7816
losi_racer's Avatar
Originally Posted by Trevor Williams
V2 tower question.............
just install and redo race roller settings?? nothing else needed I guess??
yup, readjust camber and ride height. I did a little more to help rotate even more. youll like the tower
losi_racer is offline
Old 06-16-2010 | 08:40 PM
  #7817
JAMMINKRAZY's Avatar
Try this setup.
JAMMINKRAZY is offline
Old 06-16-2010 | 09:25 PM
  #7818
deadmancourt's Avatar
anybody got a 2.0 truggy chassis and center to rear cvd for sale?
deadmancourt is offline
Old 06-16-2010 | 09:50 PM
  #7819
Frank L's Avatar
I prob have a used 2.0 chassis I can sell you. Let me look and I'll send u pics if it looks ok.
Frank L is offline
Old 06-16-2010 | 09:53 PM
  #7820
bigjayjay1's Avatar
I have one also if Frank doesn't
bigjayjay1 is offline
Old 06-16-2010 | 09:54 PM
  #7821
as long as i can use it and its not broke i want it!...how much?
Old 06-16-2010 | 10:42 PM
  #7822
bigjayjay1's Avatar
Old 06-17-2010 | 06:10 PM
  #7823
Gearhead racer's Avatar
Can the rear links be cut down to make the proper length for the v2 tower? Looking to order the tower and needed to know if i need to order something else.
Gearhead racer is offline
Old 06-17-2010 | 07:00 PM
  #7824
reggie l.'s Avatar
yes, that is what me and others did before losi and khz brought out the v2...
reggie l. is offline
Old 06-17-2010 | 09:00 PM
  #7825
Frank L's Avatar
You can order front links that way you can switch back. Heres a link they work well. http://www.amainhobbies.com/product_...buckles-w-Ends
Frank L is offline
Old 06-17-2010 | 09:11 PM
  #7826
That is what I did also, but I am running the outside lower hole on the tower...
jonski is online now
Old 06-18-2010 | 06:23 AM
  #7827
offroad racer's Avatar
Default I NEED HELP ASAP
Hey guys I have a problem and I need answers ASAP. So yesterday I ran my truck for about half a tank to get the bearings in the clutch broken in. When it stopped I looked at it and I noticed that there was fuel on the back of the chassis and on the rear brake pad. I also noticed that there was some oil-like substance on the engine. this was also the first time running my truck with the fuel filter on also.
Here are my questions:
1: What is the oil-like substance?
2: How did the fuel get on the back of the chassis?
3: Where did the oil stuff as well as the fuel come from?
4: What can I do so this won't happen again?
5: Why did this happen?
offroad racer is offline
Old 06-18-2010 | 07:45 AM
  #7828
Make sure the gaskets on the exhaust are making a good seal...check the one on the motor and the one between the header and pipe.
Old 06-18-2010 | 08:03 AM
  #7829
MaSt's Avatar
Hi guys.
Whitch clucth sprigs i need to use form Dynamite maxlife clutches, to get like losi standart clutch setup?
MaSt is offline
Old 06-18-2010 | 08:50 AM
  #7830
Brushlessboy16's Avatar
Hello Losi fans, i have a setup question. I have a losi 8ight T 1.0 Race roller, and shes still competitive! set a 39.1 second lap on my home track, fastest of the day was 39.0
My truck's rear end kicks out ALOT when i get off the brakes on our straitaway into a 90 degree right hander, how do i keep the rear from stepping out?
I was thinking heavier front shock oil to prevent weight transfer.
I run purple rear springs, black in the front.. had silvers in the rear before.
Running aka city blocks on 1/2 offset rims, track is clay, plenty of grip- truck will wheelie
- how would i remove the rear end kicking out
- Is there a list of losi spring tensions, so i know what springs to get if i ever want to swap them?
- What would a shorter or longer camber link do on my truck?
Brushlessboy16 is offline
