HELP! Dynamite Passport Ultra Question >
Old 05-31-2010 | 12:37 PM
Default HELP! Dynamite Passport Ultra Question
I have owned a Dynamite Passport Ultra for about 2 months now. Everything was fine until this weekend.
I plug a Lipo and plug the balancer. As soon as I hit start on the balance charge mode, the very next second there is an error flashing. "STOP" , "OPEN", "STOP" , "OPEN"
I tried charging 2s and 4s and I get the same error.
HELP
bluebon88 is offline
Old 05-31-2010 | 12:48 PM
turbowop's Avatar
Open means your charger isn't seeing continuity on one of the wires. Check all connections on balance plugs, etc.
turbowop is offline
Old 05-31-2010 | 01:20 PM
THANKS TURBOWOP!!
I will give that a try. Has anyone ever seen that "STOP", "OPEN" error on thier Dynamite Passport Ultra before??????
THANKS FOR ALL THE HELP!!
Old 05-31-2010 | 01:28 PM
turbowop's Avatar
I've seen this happen to a couple friends with the same charger. Usually due to a balance wire that wasn't plugged in on a hard case LiPo. Haven't seen it on my personal Passport Ultra though.
turbowop is offline
Old 05-31-2010 | 01:32 PM
The thing that concerns me is why isn't that error on the manual. Unless I have missed it. I went over it about 5 times and can't find that error description.
Turbowop,
What happened to your friends chargers...are they working fine after they fixed the wire on the balancer?
Old 05-31-2010 | 02:03 PM
turbowop's Avatar
The problem wasn't with their chargers, it was with the balance wire on the battery.
turbowop is offline
Old 05-31-2010 | 02:17 PM
Top of page 15 in your manual -
"Warning Information
1. If the battery connection is lost during
operation, the OPEN/STOP error will flash.
Reconnect battery or replace."
Duster_360 is offline
Old 02-13-2011 | 02:49 PM
smkmoto's Avatar
So, you guys recommend this charger? Would you buy it all over again?
Thanks!
smkmoto is offline
Old 02-15-2011 | 07:53 PM
I got the open/stop error once, after I reversed the battery leads . I called Horizion and sent in my charger. 8 days later they sent me one NIB. I don't know what I did internally but you could smell the magic smoke was set free. Does yours smell burned at all?
thefatkid is offline
