The Speed Passion Thread >
Like Tree57Likes
Old 05-25-2010 | 10:12 AM
  #4441
Originally Posted by Bryan D
Can someone who has run V2 and V3 motors tell me what are the main differences between them apart from looks and connections??
V2 motor is for STOCK SPEC racing, which use the stand connection (solder thru holes) and has no timing advance feature....low budget spec motor.
V3 motor is for Stock to pro MOD racing...which use the new bullet plugs wire system so you can swap motor without soldering wires in and out...it has 0 to 10 degrees of advance timing on motor can.....high end competition motor.
Solara is offline
Old 05-25-2010 | 10:22 AM
  #4442
Joel Lagace's Avatar
i just started to run the V3 motors.. I like them alot. For car maintance there is no longer a need to pull out the iron. sold once and your done with it.. Nice time saver..
Only thing to note... IF your like me and run short wires you'll need a new set of 3 wire to reach the power posts.. On my B4 i had to run new wires.. not a big deal just and fyi
Joel Lagace is offline
Old 05-25-2010 | 10:35 AM
  #4443
Originally Posted by charlie_b
9.0 FDR
9/1
12/3
13/9
14/5
15/6
Remember, these are general settings. Track conditions and personal driving styles vary. Use these settings at your own risk.
can i used 3.0t motor with this setup.. i mean this FW 422can support 3.0t motor?
wan161111 is offline
Old 05-25-2010 | 11:10 AM
  #4444
Software 100422 can support any turn motor...it is the SPEED CONTROLLER that you have can or cannot support low turn motor....
What is your SP speedo..? GT2 pro or GT2 LPF or GT2.1 Pro stock..?
Solara is offline
Old 05-25-2010 | 11:25 AM
  #4445
im using sp GT2 pro.. the manual say this esc only support 3.5t motor, in gt2 lpf manual, gt2 pro can support 2.5 motor, im so confuse..u have any suggestion or advice setup for 100422 to running 3t motor with turbo boost
Old 05-25-2010 | 12:22 PM
  #4446
razzor's Avatar
if you want to run a 3.5 just stick to the 205G or 323 firmware, less chance you going to fry the motor.
It can be run with the new software but you need to know what you doing and run low timing values or motor will overheat.
razzor is online now
Old 05-25-2010 | 12:33 PM
  #4447
If you are running SP GT2 PRO...you can run 3.0T motor...you have the base mod setup above provided by the SP Team driver over Europe already...
1 thing I would do is get your final drive to 10 instead of 9....I just don't like to start anything below 10 with mod motor especially 3T and supercharger. Then you can check motor temp and infield performance and gear accordingly.
1/1
2/3
3/1
4/4
5/1
6/1
7/1
8/1
9/1
10/1
11/-
12/3
13/9
14/5
15/6
Solara is offline
Old 05-25-2010 | 01:19 PM
  #4448
Originally Posted by Ahmed Aman
I drove his car and it definitely hasn't got anything to do with the battery.
It seems really random whether the punch will kick in or not and when it does it feels flat at lower speeds anyway. We have tried different timing settings from 0 to max, but the result was always the same.
I have the same issue, to solved it I change the internal motor sensors
and problem solved, this evening a friend has the same problem he changed
the ESC for a tc spec and the problem was the same, changed the internal sensor problem solved.
good luck
Ed
eded1 is offline
Old 05-25-2010 | 02:45 PM
  #4449
1/1
2/3
3/1
4/4
5/1
6/1
7/1
8/1
9/1
10/1
11/-
12/3
13/9
14/5
15/6
I would probably not run setting 9 at 1. All that would do is make the car have a ton of torque and no top speed. Also it would negate the timing change system. Why bother having the new software if you are not going to use it?
With 205 we used 26 degrees flat line thoughout the range with no troubles. So why not have setting 9 at say5-8? I would not run any turbo though. I would make the start rpm very high and setting 15 should be quite a high to keep it cool.
But to be honest a 3T would be no good however you set it up. Europes best drivers were using 4T+ from what I have seen in reports on that huge track. Rubber tyres can only grip so much.
Mike
ixlr8nz is offline
Old 05-25-2010 | 06:44 PM
  #4450
Could anyone confirm if this new SP rotor made from a neodymium ? (Product ID: RS13803NA)
http://www.kinggolden-rc.com/pdtdeta...?pid=rs13803na
leonardiw is offline
Old 05-25-2010 | 08:09 PM
  #4451
1/1
2/3
3/1
4/4
5/1
6/1
7/1
8/1
9/1
10/1
11/-
12/3
13/9
14/5
15/6
tq for the info, i will try this setting soon..
Old 05-26-2010 | 02:43 AM
  #4452
Default GT2.1 Prostock confusion?
Hi,
I'm confused about the new GT2.1 Prostock ESC.
Can somebody from SP please give a definitive answer about whether or not the GT2.1 can run low turn MOD motors or not, please? I've searched through this forum and found conflicting answers.
I'm aware that you need to change to the MOD firmware to do it, I don't have a problem with that. Just want to know if it's the same as the GT2.0 Pro inside. If not, why is it the same price?
Also, I can't find any specs for the GT2.1 either. I'd like to know max current, resistance, etc. Anyone have a link to that info?
Thanks for any help.
Cheers, Frank
Frankgw is offline
Old 05-26-2010 | 03:00 AM
  #4453
cyclone speed's Avatar
Hi , u just purchase a GT 2.0 LPF , limit of 5.5 t, is ut any good esc for 13.5t racing ? I dont think il be racing mod, but I do have a LIPO battery, so I'd like to know if the GT LPF is good or not ?
Also, can i programe it via PC ? Are the instructions clear about firmwares, seting up and bla bla bla....
Does the ESC heat up easly ? Does it have reversed polarity protection ?
Thank you
cyclone speed is offline
Old 05-26-2010 | 05:46 AM
  #4454
wolvesbane's Avatar
Hi guys I`m in a bit of a bind, I just bought a new stock spec GT2.1 it`s had latest FW upgrade and running a new SP 17.5, It won`t rev over about 25%, at full throttle. Checked every thing I can think of, light flashing in bottom of esc, any one have any ideas? I have state titles this weekend, so could really use a quick fix, cheers, Dave.
wolvesbane is offline
Old 05-26-2010 | 06:20 AM
  #4455
nnick's Avatar
Shop Owner
I must add that there V2 motor for high end competition.
Actually, because SP forgot to send the V3 motors for homologation to IFMAR V2 are the motors SP drivers will.
Having run both (4.5t) I must say that both are very fast and reliable. V3 apart from the obvious advantage of swaping motors fast and hassle free, they are colder although they need to gear them higher
nnick is offline
