8T 2.0
Old 05-25-2010 | 11:34 AM
  #7411
JAMMINKRAZY's Avatar
7/10/3 truggy and 5/5/3 or 5/7/3 buggy. Those are what I usually run.
JAMMINKRAZY is offline
Old 05-25-2010 | 12:50 PM
  #7412
Integra's Avatar
Originally Posted by Trevor Williams
Nick.........have all the minor issues of the old race roller 2.0t been fixed? shock ends, servo saver etc.........Im thinking about going back to 2.0t.
saver yes...back to the 1.0 style....Shock ends are still iffy...double check them and have some spare's on hand.
Originally Posted by Frank L
I have been thinking about going back to reg diffs. I have been running sd's for ever. In the truggy where is a good place to start 7-10-3? Andi know this is the truggy thread but can you give me some pointers for the buggy too. 5-5-3? In the buggy? I didn't want to post in 2 threads. Thanks. J know the electrics are different but I was told to pu. 10-7-4 in it and it smoothed it right out. Any advice is apprecitated.
I also pulled my Center SD in truggy for this past weekends race and used the norm 7-10-3 and really didn't notice much difference. The track was favorable for the SD as it was rather loose and somewhat bumpy but i honestly didn't feel the need for the SD...the Standard diff worked just dandy...Took Tq and the win to boot.
buggy i've always ran 5-5-2....Ive been tempted to try 7 in the center but rarely have the traction to justify it.
Maybe this weekends JC race in Omaha might change that tho.
Integra is offline
Old 05-25-2010 | 01:11 PM
  #7413
I guess I'm lucky. We get to run on high traction all the time around here.
Old 05-25-2010 | 01:13 PM
  #7414
Default bump box
I broke the belt in my bump box today. Unfortunately I didn't get a chance to after run the motor and am scrambling to borrow one locally for that.
I want to buy a second bump box, any suggestions?
nitro-rob is offline
Old 05-25-2010 | 01:14 PM
  #7415
Ofna truggy start. Best box around. Twin 775's.
Old 05-25-2010 | 01:19 PM
  #7416
Default thank you
Thank you. I called the local shop and they have them in stock. A broken bump box was not something I anticipated, but having two of them solves the problem.
Old 05-25-2010 | 04:12 PM
  #7417
Hate2Looz's Avatar
Diff oils for me = 7/10/3 for the truggy, 5/5/2 for nitro buggy and 5/7/2 for electric buggy.
X2 on the Ofna truggy bump box. Add a lipo and its dialed.
Hate2Looz is offline
Old 05-25-2010 | 04:14 PM
  #7418
cdbias's Avatar
How do you guys like running 3,000wt in the rear diff opposed to the standard 2,000wt diff fluid?
When I tried 3k it made the truck feel a little "pushy".
cdbias is offline
Old 05-25-2010 | 04:17 PM
  #7419
reggie l.'s Avatar
2 fades too quick.. once the 3 wears in it wont push
reggie l. is offline
Old 05-25-2010 | 04:20 PM
  #7420
Yep
The 2k breaks down very quickly, especially in the truggy. The 3k will feel a tad less responsive at first, but once it wears in a bit, it stays right in the "golden zone" for much longer than the 2k does.
Old 05-25-2010 | 04:28 PM
  #7421
reggie l.'s Avatar
Originally Posted by JAMMINKRAZY
Yep
yep! thats the best way to explain it
Old 05-25-2010 | 04:57 PM
  #7422
Slider30250's Avatar
What truggy diff oil's would you guys normally run for loose\slick track conditions?
Slider30250 is offline
Old 05-25-2010 | 05:10 PM
  #7423
Thanks for the suggestion on the bump box. Its way better than the RTR box. My engine is so tight.
You guys are making me want to race.
Old 05-25-2010 | 06:00 PM
  #7424
Frank L's Avatar
Thanks for the diff oil suggestions. I am going back to reg diffs and see if I like them still.
Frank L is offline
Old 05-25-2010 | 06:41 PM
  #7425
teamlosi906's Avatar
Default losi
question i just replaced all the screw hardware with the titanium kit and titanium turn buckles and camber links , now with losing so much weight should i run lighter shock oils or springs ?
teamlosi906 is offline
