shoegoo for mounting electronics
#16
I've read that silicone gives off something as it cures (acetic acid vapor?) that is nasty for delicate electronics. I avoid it for that reason.
I think ShoeGoo is a type of neoprene, not silicone, so it may be safer.
I'm not sure about this; just throwing it out there....
Take it easy,
desmobob
Take it easy,
desmobob
With that said, if you had a constant supply of acetic acid vapors surrounding mission critical electronic SENSORS like on the space shuttle then that would be different.
To be honest, I'd be more worried about water vapor in the air over time doing damage to RC electronics than a few hours of acetic acid vapors in a well ventilated area during the curing process.
#18
Shoe Goo and/or Silicone sealant are good for sealing out water from your electronics to make it more water resistant. I don't see why you'd need to use it for mounting electronics though.
#21
I was just made aware that in the electronics industry they use something called RTV silicone sealant. The cool thing is it's designed to be used with electronic circuit boards so it's completly safe so you don't have to worry about acetic acid.
http://www.amazon.com/Pro-Seal-80726.../dp/B000FW7VNW
