shoegoo for mounting electronics
I have had several fellow drivers advise me to use shoegoo to mount esc's and receivers when I was having trouble with servo tape sticking. Anyone have any experience with this?
That's how we used to do it back in the good ole days, even mounted steering servos in some of the Bolink cars with shoe goo. I have found that if you buy 3M brand double sided tape to use for mounting electronics your problems will be over. Just wipe both surfaces clean with rubbing alcohol, then apply the 3M tape(try not to touch it with your fingers) and stick it!
^^Thats pretty much what I do except I use what 3M calls mounting tape. It has a little cushioning to it which may help isolate electronics from shocks amd vibration.
Shoe Goo will do the job though, just a little more work to clean up when you have to remove it. |
Thanks for the feedback. I got some Trinity stuff at the hobby shop I was not too fond of. I guess this is something I would find at a craft store/Walmart/hardware store as opposed to the hobby shop.
Silicone sealant will also work and easy to remove.
I could not find Shoe Goo anywhere in my town but I did find Amazing Goop. It's the same company and basically the same stuff. I don't use it to mount electronics (double-sided tape) but it's tough stuff.
Originally Posted by BrianTx01
(Post 7115293)
Yeah, I bought the 3M mounting tape at Wally World..... |
(Post 7114067)
Thank you all for the replies. It looks like I have a couple good options here.
Originally Posted by klaymon
(Post 7115591)
I don't shop there. Amazing Goop is available most places anyway. Besides, I use servo tape to mount all my stuff.
Originally Posted by spcpicard
(Post 7220742)
you can find it in the shoe dept at wally world.
Originally Posted by PaPeRo
(Post 7115330)
I've read that silicone gives off something as it cures (acetic acid vapor?) that is nasty for delicate electronics. I avoid it for that reason. I think ShoeGoo is a type of neoprene, not silicone, so it may be safer. I'm not sure about this; just throwing it out there.... Take it easy, desmobob |
I've been using Shoe Goo for at least a decade and never had an issue. It's easier to peel off than servo tape too...
Originally Posted by richard.bratton
(Post 7298303)
| All times are GMT -7. It is currently 02:39 PM. |
