8T 2.0
Old 04-25-2010 | 12:54 PM
  #6691
JAMMINKRAZY's Avatar
Originally Posted by bigjayjay1
Electric guys need to pickup a conversion kit I'm running a Tekin RX8 2250 system the only option I see are the Losi and castle any others ??? any feedback and pointer, setup will be appreciated.
I use the losi conversion kit. It's the simplest and works great! The Tekno kit looks very nice, but IMO it's too complicated with a different chassis and clutch, etc... I would recommend the losi one.
JAMMINKRAZY is offline
Old 04-25-2010 | 01:02 PM
  #6692
reggie l.'s Avatar
Originally Posted by JAMMINKRAZY
Huh? Are you talking about the lower outside hole on the tower and the B hole on the hub? If you run the lower inside hole on the tower and B hole on the hub, it will be the same as a stock truck without the v2 tower. The inner holes on the new tower are in the same position as the stock v1 tower holes.
yes i know... and casey said that stock is the best place to run them..and i agree...i changed mine back to stock and it felt alot better... he said on some tracks you MAY need to play around with them
reggie l. is offline
Old 04-25-2010 | 01:05 PM
  #6693
bigjayjay1's Avatar
Thanks thats the one I will get just wanted to make sure their wasn't another manufacture out their I wasn't aware with a awesome product. Are you running the normal diff oil setup off a nitro??
bigjayjay1 is offline
Old 04-25-2010 | 01:10 PM
  #6694
I like the feel much better with the shorter link. It may just be a preference thing, but to me the truck feels much better with the shorter link. I have done some back to back testing and to me the truck just rotates much better with the shorter link. My 2 cents.
I can't really be of much help for an E truggy setup. I just run the E buggy, not the truggy. In the buggy I run my normal nitro setup of 5/7/3. You may have to go up a bit in center oil with the truck, but I would try your standard nitro setup first. You will probably want to go up 5wt in shock oil all the way around too.
Old 04-25-2010 | 01:32 PM
  #6695
reggie l.'s Avatar
yes it does... i tried it a while back and havent went back to stock since
Old 04-25-2010 | 01:35 PM
  #6696
Didn't you just say you went back to the stock position and liked it better??? Maybe I'm just.
Old 04-25-2010 | 01:43 PM
  #6697
reggie l.'s Avatar
yes i went to the stok posistion but runing the shorter links... just like befor the v2 tower came out you shorten the links and move it to the a hole... it just makes the truck react more... you can get damn near the same effect if you have it in the b hole with the stock links...aka the "stock position" long as you have the shocks int the new hole on the tower..get it?
Old 04-25-2010 | 01:47 PM
  #6698
OK I see what you mean. I run the shorter links AND the outer shock hole. Which makes the truck rotate even better. I'm lovin that setup.
Old 04-25-2010 | 01:51 PM
  #6699
reggie l.'s Avatar
yes i do too. i was tryin to tell the guy buying the new tower what i was explaining, so he wont have as much work to do etc...
most the guys that have the shorter links are because we were testing this befor losi brought out the tower etc...
Old 04-25-2010 | 01:56 PM
  #6700
lowcel's Avatar
I run castle and I couldn't be any more happy than I am with it. I was running the 2650 but I recently switched to the 1800. I mainly switched so that I would have more run time. Initially I was a little disappointed since it was a good bit slower than the 2650. However after running a few laps I realized that I was actually faster with it since it was much more manageable.
I am running mine on 4s which is plenty fast enough in my opinion. With all this said I believe that Tekin is just as good, I've just had such good experience with castle that I haven't had the urge to try anything else.
Sorry for the electric talk, not trying to derail the thread or start any arguments.
lowcel is offline
Old 04-25-2010 | 01:58 PM
  #6701
For sure! I ran the short links for like a year before the new tower came out.
Old 04-25-2010 | 02:00 PM
  #6702
reggie l.'s Avatar
you and i both bro... guys didnt know what the hell was different about my truck on the track lol
Old 04-25-2010 | 02:03 PM
  #6703
Hehehe. Isn't that a good thing? Keeps them guessing! People still look at my truck funny sometimes.
Old 04-25-2010 | 02:05 PM
  #6704
reggie l.'s Avatar
hell yea, asking what set up you run etc..lol
Old 04-25-2010 | 02:07 PM
  #6705
techpro's Avatar
I tun lower inside on the tower and A on the hub. I've been running it like that for a long time. You have to shorten the camber link a bit or run a camber link from the front of the truck. I also run a 2.0mm sway bar in the rear. This setup came from Casey Peck and Billy Fischer.
I ordered a set of turnbuckles from the rear of the 1.0 truggy they are 100mm,hopefully they wont be to short compared to the front turnbuckles of the 2.0 at 107mm,thanks for the help.
techpro is offline
