8T 2.0
Old 04-23-2010 | 03:00 PM
  #6646
Muggydude's Avatar
X4 I used to use paper, but over the years I can tell if it's just right by the sound of the clicking and how far I can wiggle the cb.
Muggydude is offline
Old 04-23-2010 | 03:12 PM
  #6647
JAMMINKRAZY's Avatar
I agree once you get a feel for what it should be, it's easy to do by feel. I still use a piece of plastic parts bag though. It's just easier and sets it dead on every time.
JAMMINKRAZY is offline
Old 04-23-2010 | 08:28 PM
  #6648
mrbusta's Avatar
can some one here plz explain wich is softest to hardest in the spring rates i have purple silver white green thanks in advance
mrbusta is offline
Old 04-23-2010 | 08:33 PM
  #6649
Softest to hardest out of those would be... Silver, Green, White, Purple. I know there is a chart of all losi springs in order with their rates listed floating around somewhere. Off the top of my head I believe it goes something like this... Red, Silver, Black, White, Gray, Purple. I may have missed a couple.
Old 04-23-2010 | 08:47 PM
  #6650
mrbusta's Avatar
Originally Posted by JAMMINKRAZY
Softest to hardest out of those would be... Silver, Green, White, Purple. I know there is a chart of all losi springs in order with their rates listed floating around somewhere. Off the top of my head I believe it goes something like this... Red, Silver, White, Black, Gray, Purple. I may have missed a couple.
thank u kind sir
mrbusta is offline
Old 04-23-2010 | 09:02 PM
  #6651
TIX's Avatar
TIX
The full range goes in this order
Red
Silver
Green
Black
White
Grey
Purple
TIX is offline
Old 04-23-2010 | 09:09 PM
  #6652
Red
Silver
Green
Black
White
Grey
Purple
That's right, Black is softer than White. My bad.
Old 04-23-2010 | 09:30 PM
  #6653
mrbusta's Avatar
Red
Silver
Green
Black
White
Grey
Purple
thanks guys
mrbusta is offline
Old 04-23-2010 | 11:05 PM
  #6654
TIX's Avatar
TIX
Are you back racing the losi Busta
TIX is offline
Old 04-23-2010 | 11:42 PM
  #6655
mrbusta's Avatar
na mate some one asked me thats all thanks
mrbusta is offline
Old 04-23-2010 | 11:58 PM
  #6656
dnebout's Avatar
Originally Posted by Frank L
No shims here and the truck drives great. I do have a question about shims in the rear gearbox. I recently replaced the ring and pinion and pit the stock shims back in , 2 on each side. There seems to be a high spot where the mesh gets a little tighter. Do I shim to the highest spot or let it wear in? I have 1-5 min qual and a 20 min main on it and it still has a high spot. Reshim or leave it alone?
Hey Frank,
Did you ever get the shimming down on the rear end. I've tried a few times, but was unsuccessful
dnebout is offline
Old 04-24-2010 | 04:32 PM
  #6657
cdbias's Avatar
For whatever reason the mesh in the Losi manual doesn't work for my truck. If you are facing the rear of the truck I use 2 of the .25 washers on the left side and 3 of the .10 washers on the right side (half moon insert).
I ran the same ring and pinion gears for over a year so I am pretty confident in this mesh.
I've always wondered why the manual settings don't work in my truck. Maybe someone else could chime in with what they have found.
cdbias is offline
Old 04-24-2010 | 04:53 PM
  #6658
lowcel's Avatar
I raced my new 8T2 for the first time today and all I can say is WOW!!! I am amazed at how much better this truggy handled than the 1.0 that I had before. There really is no comparison to the way that it handles. There were so many times where I would have lost it with the other buggy that this one just kept right on going. It is just so much more stable. I am sold!
lowcel is offline
Old 04-24-2010 | 05:00 PM
  #6659
No 2 R&P sets will shim exactly the same. Even trying to use the same shimming for two different sets WILL lead to issues. If you shim them correctly, I think you will find that they are all a bit different.
I personally shim mine with almost zero backlash. In fact I do shim them with zero backlash from the beginning and when they wear in, I re-shim them back to almost zero. You have to keep them really tight or they will blow out.
When shimming them like this, you will get that notchy feel at least in one spot. This is fine, and will wear in with time. As long as it doesn't lock up the notchy spot won't cause any problems. I also recommend using a good grease like Mobil 1 red bearing grease on the R&P.
Old 04-24-2010 | 05:09 PM
  #6660
Glad you like it! It looks good.
