Ofna Force .21 JL
Old 04-21-2010 | 04:28 AM
  #691
neobart's Avatar
Dangling the bait are we?.....
Didn't take you for a fishing man Neal.
neobart is offline
Old 04-21-2010 | 04:30 AM
  #692
Maximo's Avatar
LOL ! After owning 3 of my engines how many drag races do you think we lose ! LOL
<object width="640" height="505"><param name="movie" value="http://www.youtube.com/v/svbaqFOW_5Q&hl=en_US&fs=1&"></param><param name="allowFullScreen" value="true"></param><param name="allowscriptaccess" value="always"></param><embed src="http://www.youtube.com/v/svbaqFOW_5Q&hl=en_US&fs=1&" type="application/x-shockwave-flash" allowscriptaccess="always" allowfullscreen="true" width="640" height="505"></embed></object>
Maximo is offline
Old 04-21-2010 | 04:45 AM
  #693
Maximo's Avatar
A Little bait !!
http://www.youtube.com/watch?v=svbaqFOW_5Q
Maximo is offline
Old 04-21-2010 | 04:51 AM
  #694
neobart's Avatar
I love that wheelie, it seems like it would hold as long as you could keep power on it.
neobart is offline
Old 04-21-2010 | 04:53 AM
  #695
Ananda Robinson's Avatar
Originally Posted by Maximo
from what we have seen so far I think the JL will eat that FMS and not even break a sweat.....
I have seen and done this first hand.
Ananda Robinson is offline
Old 04-21-2010 | 04:56 AM
  #696
easyryder's Avatar
Originally Posted by Jaz240
who you kidding? Do you have any idea how awesome it is to not have to break in an engine!!!!???? I could care less if its modded or not, but give me hand lapping every time brohemian Rapsody
If i was Mark Popadockolis and I got free engines and someone to break them in for me, I would be running stock speeds also
I like breaking in engines, it gives you time to develope a bond with your engine Some engines are worse than others, the JL breaks in quite nice as is
easyryder is offline
Old 04-21-2010 | 05:03 AM
  #697
easyryder's Avatar
Originally Posted by nukem
Its available here in the Philippines , branded as FC Power Engine, Force Model Co., Limited same as JL Force inside, I won novice class in one of our races here.
Never flamed out on me
Lots of our racers are now running this engine... it's a very nice engine
Do you have a link, Back when these first came out I scoured the web for info, no luck. Force model seems super secretive Thanks!
Old 04-21-2010 | 06:29 AM
  #698
Timmo's Avatar
I'll take your money ! if it happens consider it a bet !
If you can get it on video and prove a fair race between the two,you will get the cash.I just wanna see it.
Timmo is offline
Old 04-21-2010 | 06:57 AM
  #699
lsbully's Avatar
I got my JL yesterday, sealed carb and backplate and got it mounted, I have ran 2 tanks thru it so far, and everything is great, engine idles like a purring kitten. I am breaking it in with Byrons 20/12, and a Picco p6tc plug
My question is when do I start pulling head shims out and how many, I will be switching to Byrons 25/11 after break in.
lsbully is offline
Old 04-21-2010 | 08:07 AM
  #700
easyryder's Avatar
You can pull one shim 1 it comes with 4. I use 30 byron and run all 4, runs great.
Old 04-21-2010 | 10:20 AM
  #701
NitroFreakManHo's Avatar
I dismantled my engine and took some pictures. I've put 2 hard gallons through it, most of it on pavement, and about a litre on the track now that it's finally open.
I was very surprised when I opened it up. I've never had an engine look this good at two gallons. It has absolutely no slop at TDC, no matter what I did. I measured my con-rod and crank-pin, and there's zero wear.The grooves in the piston look just as deep as day one. Very impressive for a 'bargain' mill that is slaying down more expensive engines...it's certainly not the Taiwan we're used to seeing.
When you consider the hard life this engines has had, it makes it even more impressive. When first getting it, I idled half a tank through it before hammering on it, and putting it to race tune. I'd say it's lived 65-75% of it's life at WOT while I was testing out different pipes. Also consider that because of the mod, it running at a higher level than it was designed to, so for it to be in great shape, with no slop, is amazing.
This engine makes it hard to justify buying another high-dollar engine again, especially if it ends up having a fairly long life. Time will tell.
NitroFreakManHo is offline
Old 04-21-2010 | 11:03 AM
  #702
Maximo's Avatar
Wow that looks fantastic Nid ! the fitted piston sure takes the wear and tear out of the engine..... I mean your engine was hitting over 40 000 RPM at tank 1, and has been run wide open nearly its entire life and the engine looks like brand new after 2 gallons ! dam wicked engine and by far the best build quality I have ever seen from a Taiwanese engine.......I am very happy to see how clean that engine looks, especially after you beat on it so badly ! cheers Neal !
Maximo is offline
Old 04-21-2010 | 11:15 AM
  #703
neobart's Avatar
Dang, if it weren't for the slight discoloration of the plug you'd think it was a brand new engine there.
neobart is offline
Old 04-21-2010 | 03:08 PM
  #704
Jaz240's Avatar
Very impressive Nid! What fuel are you running?
Jaz240 is offline
Old 04-21-2010 | 05:34 PM
  #705
easyryder's Avatar
Looks Good!
