Do dents & dings hurt ur pipes performance?
anytime you dent a pipe it effects performance so the answer is yes . I have popped dents out of pipes by using the freezing method mentioned above .
Tech Prophet
Be very careful with the 2013 and the freezer , that thing is thin and will pop out easily !! But if the underside of the pipe is flattened out the freezer trick will not save it .
Do not leave it in freezer for days. Just check it frequently and pull it out if dents pop out.
Or just buy a new pipe
hey brother from another mother! buy a new pipe cheap sk8!
I've seen motorcycle pipes blown out with a little air pressure and heat. This might work on a thin RC pipe??
