Like Tree2991Likes
1/12 forum
Old 03-12-2010 | 06:54 PM
  #33736
Bmr4life's Avatar
How fast are these cars using going when carpet racing?
Bmr4life is offline
Old 03-12-2010 | 06:56 PM
  #33737
kk4hg's Avatar
Originally Posted by buffalobill989
http://tqracing.com/sensor.htm
i think they are all the same. heres what i use
some of the best. very flexible. i use these and his wire to
Thanks! So I don't need to specify motor and ESC, just the length?
kk4hg is offline
Old 03-12-2010 | 11:58 PM
  #33738
Originally Posted by W.E.D.Jim
stical, I replied to all the pms, thank you for your interest!
lmk
...Jim
W.E.D.
www.wedjim.com
Hi Jim,
PM replied and payment sent.
This will be my first pro-painted body YEAAAHH
Thanks,
Erik
stical is offline
Old 03-13-2010 | 01:31 AM
  #33739
TrevCoult's Avatar
Originally Posted by carcrazy699
hey guys thinking of running a 12th scale. i have the tekin rs esc and was woundering if i stil need to get that smart boost from novak to run
Don't get the Novak booster. The LiPo cutoff is set too high. Get the TQ booster or better the RC Dynamics one from the UK (www.rcdynamics.co.uk) which has better performance. Neither have a LiPo cutoff but they are not really needed if running stock classes.
Trev
TrevCoult is offline
Old 03-13-2010 | 02:25 AM
  #33740
jmellipse's Avatar
@carcrazy699
If you wil be running NiMh you don't need them.
The Novak is very big and has a lipo cutt-off. You already can do lipo cutt-off with your Tekin RS if you want. This is only possible with the higher software version. Not sure where it started, but v203 has it.
jmellipse is offline
Old 03-13-2010 | 08:26 AM
  #33741
avs's Avatar
avs
yes, brushless sensors all use the same connector.
avs is offline
Old 03-13-2010 | 10:04 AM
  #33742
wingman2's Avatar
I recently used a Novak booster but it would not work with the latest 203 S Pro. I had to uninstall the 203 software, and use the previous version just to get it to work. Since then, I have bought a TQ booster and have had no problems with it at all. Cheers.
wingman2 is offline
Old 03-13-2010 | 10:15 AM
  #33743
Mark506's Avatar
How does the angle of the turnbuckles from the servo, to the knuckles correspond to feel in steering? With running a flat servo, I guess more bump steer is produce than running a angled servo, mostly because a flat servo has more of a incline starting at the top with the horn with the turnbuckles, than a angled servo. Is that right so far?
So would shimming 1.5mm under the ballstud on the knuckles to produce less turnbuckle inclined, almost parallel to the chassis, produce a more linear feel with ackerman, and almost be a balance between a flat and angled servo? thanks.
Mark506 is offline
Old 03-13-2010 | 10:23 AM
  #33744
CarbonJoe's Avatar
Regional Moderator
Originally Posted by Mark506
almost Parrnell to the chassis
I assume you meant "parallel to the chassis"?
CarbonJoe is offline
Old 03-13-2010 | 10:27 AM
  #33745
Mark506's Avatar
Yes, fixed, thanks
Mark506 is offline
Old 03-13-2010 | 05:50 PM
  #33746
Josh Keller is offline
Old 03-13-2010 | 07:29 PM
  #33747
kk4hg's Avatar
Default 1/12 Newb ?
Getting ready to build an Assoc. 12R5. Can't see where it says how much oil to put in the two shocks...
kk4hg is offline
Old 03-13-2010 | 10:32 PM
  #33748
pakk's Avatar
never mind, read that wrong.
pakk is offline
Old 03-13-2010 | 10:36 PM
  #33749
u need to fill the shock up so there is no air in the shock itself. Once shock has been filled pump the piston a few times to make sure there is no air trapped under it. When fitting the top plate and oring make sure the plate is pushed all the way in then push the oring in as well. the oring should be pretty much flush with the top of the shock body. Fit cap making sure its not cross threaded
dangles is offline
Old 03-13-2010 | 10:51 PM
  #33750
kk4hg's Avatar
Thanks, mate!
kk4hg is offline
