Like Tree2991Likes
1/12 forum
Old 02-05-2010 | 06:58 PM
  #33481
<PsOp>
Guest
Posts: n/a
Thanks!
Old 02-05-2010 | 07:50 PM
  #33482
Integra's Avatar
Originally Posted by Grenade10
Kind of depends on your electronics. Some ESC's, Receivers and Servo's can run on lower voltage, but the ESC will normally take power over receiver and servo, which is not always good. Some ESC's or receivers will not run with out enough volts.
You can run a booster, but with the new software like Tekin's 203 the Novak will actually brown out when the power is pulled really hard to the motor. (actually the ESC has to re-boot) One of the other boosters will work, but they get pretty hot on oval and 10,5 in 1/12 scale. You can use a receiver pack, but if 2 cell lipo, you should use a regulator to not over drive the electronics, can burn them out. I've gone to a 2 cell LiFe pack which has the right volts, small in size and enough amps so you can run 2-3 8 min run with out issue.
Hope that helps.
what life pack may i ask ?
Integra is offline
Old 02-06-2010 | 01:05 AM
  #33483
TrevCoult's Avatar
Hope that helps.
The only booster I have not had a problem with is the RC Dynamics booster. Just as reliable as a RX pack and easier to use. I actually bought a couple of LiFe RX packs at the same time as a backup but I've never used them.
Web site is www.rcdynamics.co.uk.
Trev
TrevCoult is offline
Old 02-06-2010 | 06:38 AM
  #33484
Another plug for the RC Dynamics Booster. It really is a fit-and-forget item. Lighter than any receiver pack, smaller and more reliable. I won't bother buying a new speedo when they all get the new BEC circuits fitted, as it isn't worth the money when you have one of these.
With the Tekin speedo, you can set the LiPo (1S) cut-off in the speedo and switch it on, so no problems there. This booster has had no cut-outs, no brown outs, just reliable power to the electronics, and plenty of it! HTH
SlowerOne is offline
Old 02-06-2010 | 09:22 AM
  #33485
Grenade10's Avatar
Trev
I had not seen that booster, but looks and sounds good. The two different ones that I tried, got too hot for my liking in the car, so I'm good with the LiFe 220ma receiver pack. Size is about the same as a transponder but maybe twice the height.
Grenade10 is offline
Old 02-06-2010 | 09:44 AM
  #33486
Randy or Yang.
I am running 1/12 scale with a 2 cell receiver pack plugged directly into the receiver with no regulator. Is this to much voltage for the speedo? Long term can it burn it up?
Jeremy Otis is offline
Old 02-06-2010 | 10:37 AM
  #33487
Originally Posted by Jeremy Otis
Randy or Yang.
Why would it be too much for the speedo? It's not plugged into the speedo. It may be too much for the RX unless the RX is designed to take more than 6V. You want to make sure the RX and servo can handle more than 6V. I run a Spektrum RX and a digital KO servo and all is dandy, runs like a dream.
EVILGRAFX is offline
Old 02-06-2010 | 11:12 AM
  #33488
odpurple's Avatar
If the red wire between the esc and reciever is in place then the receiver pack is sending 7.4v to the esc control cirquit. Of all the Novak, LRP, Tekin and KO escs I have used you do not need to remove the red wire to use a receiver pack or booster. Whether the esc can handle 7.4v or not might be determined by where in the series the bec (battery eliminator cirquit) inside the esc is placed, and I don't know the answer to that. Anybody?
odpurple is offline
Old 02-06-2010 | 11:18 AM
  #33489
theisgroup's Avatar
Randy or Yang.
i have asked randy before and he has told me that it was fine. also robert at ko said all the ko stuff was ok with 2cell lipo rx packs as well
theisgroup is offline
Old 02-06-2010 | 11:23 AM
  #33490
How about JR servos?
InspGadgt is offline
Old 02-06-2010 | 12:07 PM
  #33491
Most manufacturers web sites have the specs listed, even older servos.
Old 02-06-2010 | 02:35 PM
  #33492
The older 3550 does NOT like 7.4 volts where the newer 3650 is OK from what I hear of the guys running them. I use a booster with the 3550 with no issues.
SteveL is offline
Old 02-06-2010 | 05:56 PM
  #33493
Troy Mckune's Avatar
Default Personalized Pod Plates for GenX10 and Gen XL
For those of you that have expressed interest, I have updated the website and am setup to take orders for personalized pod plates. Prior to Snowbirds, I made up two each for some of the CRC drivers: Hupo, Frank, Bryan, Mario, Dave Ehrlich, and Brian Bodine. Dave handed them out at Snowbirds and said they were a big hit with the drivers. If you have any questions please pm me on RCtech or email off my website.
The website is setup to take orders for individuals wanting 1 or 2+ engraved with our standard font (Arial Black Italic Bold) filled with white acrylic paint. Leadtime is 1-2 weeks plus shipping. I will take custom orders of 10 or more for teams, hobbyshops, or manufacturers. Email or Call for pricing (visit website's contact us page).
Troy
Attached Thumbnails 1/12 forum-picu0977.jpg   1/12 forum-troymckunepp.jpg   1/12 forum-troyppiso.jpg   1/12 forum-timezonepp.jpg
Troy Mckune is offline
Old 02-06-2010 | 06:15 PM
  #33494
lavaandy's Avatar
I run the 3650 and 3550 both on 7.4, if you don't run a regulator you may have to change the frame rate on your radio, I have to run one slower on frame rate when I don't run a regulator, if I don't change frame rate the servo will not center consistency
lavaandy is offline
Old 02-09-2010 | 08:23 AM
  #33495
<PsOp>
Guest
Posts: n/a
Default What tires!
I'm new to pancars so I need to know what tires to get (shores/colors). I'll be running it in two different surfaces carpet and indoor tarmac plus do I really need to true the tires? at what size thanks.
