Tamiya TRF415
#691
Originally posted by markp27
Hi V12,
I can confirm that the Tamiya screws are soft - I have namely two stuck in my rear suspension mounts (the aluminium things bolted onto the chassis) - the heads stripped when I tried to remove them Any suggestions how I can remove them?
Where did you get your Square Ti screws from?
Hi V12,
#692
@V12
It seems to me that you know some of the team drivers in Germany, maybe you can tell us a little more about their impressions of the 415.
#693
Originally posted by dtm
But can you confirm that another brand of Ti screw would not have done the same thing....
Cheers, Mark.
#694
on my suspension mounts i have been using some stainless hex screws from fastener express
they have been super strong, and havent rounded one yet!
#695
DTM itis not neccessarily the TI screw. I have found them a touch soft but when I switched to a ground driver from a cast one I have had far less problems. KCM, Tamiya's supplier supplies for quite a few people.
Mark also check the block if you have stripped the screw I would bet that the toe block is bent also. When they get slightly twisted it compunds the problem and screws start jamming
#696
I used Cobra81li200's method and it worked a treat - I drilled the screw head until I could lift the suspension mount with a flat bladed screwdriver - the now headless screw was easy to remove by using some pliers to grip onto the bit that was still sticking out of the block.
Thanks for the help!!!
Cheers, Mark.
#697
@ Holmenkollen
Yes I know some of them but I don´t see them very often as most of them live in another area of Germany than me. I only know Marc Rheinard does have an 415 currently and it seems to me he and Steen Graversen are the only 415 drivers in Europe at the moment. I will see Marc at the LRP TCM-Masters but this will be on 3./4. of april.
Maybe you have read a report from the DHI-Cup in Denmark where both Marc and Steen did very well at their first race with the 415. From what I know they just had one practice weekend with the 415 before.
#698
Registered User
#699
Great to see that the 415 is doing well in races. Let's see if it can take home the gold at this year's IFMAR.
#700
were u using a dremel or a power drill to do the job??
as usual, i'm having a similar problem.
thanks.
thanks.
Hi Guys,
Cheers, Mark.
Hi Guys,
Cheers, Mark.
#701
thanks.
thanks.
Be a little careful of when you get close to drilling through the head - I knew I was through the head when I could start to see what looked like the carbon chassis in the drilled out screw head.
I then unscrewed the other screw from the suspension mount and leavered the suspension mount carefully free of the almost fully drilled out screw head.
Just take a little time and care and it will workout fine!
Cheers, Mark.
#702
Stripped
Guys i had the same problem so i changed all the screws to corally torque screws.They never strip out its worth looking at.
#703
With this newest option it will be unbeatable!
WHITE BELTS
WHITE BELTS
#704
The belts are probally coated with some type of lubracant that doesn't wear off, teflon mybe, or maybe its just for show.
#705
But surely the look and its performance are all every racers wanted
