Old 01-27-2004, 02:17 AM   #691
dtm
dtm's Avatar
Send a message via ICQ to dtm
Originally posted by markp27
Hi V12,
I can confirm that the Tamiya screws are soft - I have namely two stuck in my rear suspension mounts (the aluminium things bolted onto the chassis) - the heads stripped when I tried to remove them Any suggestions how I can remove them?
Where did you get your Square Ti screws from?
But can you confirm that another brand of Ti screw would not have done the same thing....
dtm is offline   Reply With Quote
Old 01-27-2004, 03:03 AM   #692
Holmenkollen's Avatar
@V12
It seems to me that you know some of the team drivers in Germany, maybe you can tell us a little more about their impressions of the 415.
Holmenkollen is offline   Reply With Quote
Old 01-27-2004, 04:45 AM   #693
markp27's Avatar
Send a message via ICQ to markp27
Not yet I was actually thinking for the suspension mounts to use steel screws - the extra weight wouldn't make any difference to me
Cheers, Mark.
markp27 is offline   Reply With Quote
Old 01-27-2004, 06:21 AM   #694
Turbonium's Avatar
Trader Rating: 27 (100%+)
Send a message via Yahoo to Turbonium
on my suspension mounts i have been using some stainless hex screws from fastener express
they have been super strong, and havent rounded one yet!
Wes
Team Novak
Turbonium is offline   Reply With Quote
Old 01-27-2004, 09:02 AM   #695
DTM itis not neccessarily the TI screw. I have found them a touch soft but when I switched to a ground driver from a cast one I have had far less problems. KCM, Tamiya's supplier supplies for quite a few people.
Mark also check the block if you have stripped the screw I would bet that the toe block is bent also. When they get slightly twisted it compunds the problem and screws start jamming
UF1 Seattle - SPEEDWERKES - VBC Racing - Team ORCA
Difuser is offline   Reply With Quote
Old 01-27-2004, 09:47 AM   #696
markp27's Avatar
Hi Guys,
I used Cobra81li200's method and it worked a treat - I drilled the screw head until I could lift the suspension mount with a flat bladed screwdriver - the now headless screw was easy to remove by using some pliers to grip onto the bit that was still sticking out of the block.
Thanks for the help!!!
Cheers, Mark.
Old 01-27-2004, 12:42 PM   #697
V12
V12's Avatar
@ Holmenkollen
Yes I know some of them but I don´t see them very often as most of them live in another area of Germany than me. I only know Marc Rheinard does have an 415 currently and it seems to me he and Steen Graversen are the only 415 drivers in Europe at the moment. I will see Marc at the LRP TCM-Masters but this will be on 3./4. of april.
Maybe you have read a report from the DHI-Cup in Denmark where both Marc and Steen did very well at their first race with the 415. From what I know they just had one practice weekend with the 415 before.
V12 is offline   Reply With Quote
Old 01-27-2004, 02:13 PM   #698
Registered User
Default 9th YAMA YAMA CUP
TRF 415 won 1st and 2nd place. Here's the like for the pic.
YAMA_YAMA_'04
Aku-Man is offline   Reply With Quote
Old 01-27-2004, 03:09 PM   #699
stonedgti's Avatar
Trader Rating: 15 (100%+)
Great to see that the 415 is doing well in races. Let's see if it can take home the gold at this year's IFMAR.
Team Powers | ORCA | OD 12 Racing | NorCal Hobbies | JWerks | Sonic Racing | Team Gayzer | AYO Racing | Team Hastings | Uncle Larry Concepts | Moonlight Toys
stonedgti is offline   Reply With Quote
Old 01-28-2004, 12:54 AM   #700
Windtalkers's Avatar
Send a message via ICQ to Windtalkers
were u using a dremel or a power drill to do the job??
as usual, i'm having a similar problem.
thanks.
Hi Guys,
Cheers, Mark.
Windtalkers is offline   Reply With Quote
Old 01-28-2004, 01:07 AM   #701
markp27's Avatar
thanks.
Yep, a dremel with a 3mm drill bit.
Be a little careful of when you get close to drilling through the head - I knew I was through the head when I could start to see what looked like the carbon chassis in the drilled out screw head.
I then unscrewed the other screw from the suspension mount and leavered the suspension mount carefully free of the almost fully drilled out screw head.
Just take a little time and care and it will workout fine!
Cheers, Mark.
Old 01-28-2004, 04:25 AM   #702
Why Try?'s Avatar
Default Stripped
Guys i had the same problem so i changed all the screws to corally torque screws.They never strip out its worth looking at.
TM E4
Axial Ax 10
Savage X
HobbyOne
Why Try? is offline   Reply With Quote
Old 01-28-2004, 06:35 PM   #703
Barry White's Avatar
With this newest option it will be unbeatable!
WHITE BELTS
Barry White is offline   Reply With Quote
Old 01-28-2004, 07:18 PM   #704
Tek Nickal's Avatar
The belts are probally coated with some type of lubracant that doesn't wear off, teflon mybe, or maybe its just for show.
Tek Nickal is offline   Reply With Quote
Old 01-28-2004, 07:45 PM   #705
Pyramid's Avatar
But surely the look and its performance are all every racers wanted
Pyramid is offline   Reply With Quote
TAMIYA TRF415 Xray XB8 R/C Items: For Sale/Trade 32 04-04-2008 08:50 PM
Tamiya TRF415 Crashmaster R/C Items: For Sale/Trade 19 12-13-2006 04:48 PM
Tamiya TRF415 MS NIB koabich R/C Items: For Sale/Trade 8 11-11-2005 07:28 AM
F/S Tamiya TRF415 rraden R/C Items: For Sale/Trade 20 06-10-2005 09:02 PM
Tamiya Evo IV or TRF415 TheDevil Electric On-Road 23 10-15-2004 07:27 PM
