mid motor 2wd buggy conversion
#301
From: anywhere I can race 2wd dirt,and 1/12 onroad in MI.
#304
#306
I haven't yet.. I had to move from Colorado to Alabama because of my dad's job and the government put most of our stuff in storage including most of my R/C stuff. I will be getting my stuff back in a couple weeks and have a couple projects ahead of the buggy to concentrate on but I do still plan to make a revised one. Wither or not it will be set up like a B44 I'm not sure. I have come up to a couple very interesting and radical electronic layouts that may work better as far as weight distribution and such.
#307
99% done. i kept the ball link bracing to allow for some flex.
EDIT: there we go...i had a copy in my album and deleted the wrong one...
#309
1/4 delrin. hand;ed pretty well at the track. i tried a different setup that wasnt quite as good. forgot to bring my other springs to change it back. i feel that when i get it dialed in a bit more with the front end it will be much better.
#310
you deleted the pic
I now have new tires and wheels all around, so my first real test mine should be fast. my electronics look like less of a time bomb now, I ran out of zipties so I did use 1 twist tie
#311
Rammstein- I like the triangulated ball link braces. and the all black theme . It looks real nice.
Now for the unveiling!!I been sick all this week so It took a few days to make it back to the work shop.Still feel kinda crappy, but much better than a couple days ago.Regardless, I am much happier with the shape of the rear shock tower than i was with the 1st version.
Without further delay, Heres the PSI MM-2 SCT
#314
looks awsome. I should be doing some testing this wednesday, racing this saturday, should be awsome. I'm going to start with a soft set up, mainly due to a section of the track I go slow on because it has 2 lines, a high line with noe set of jumps, a low line with another, and if you hit the middle, you might flip, so with the soft set up, hopefully it will absorb most o it without flipping as I go slow there to get lined up so I don't hit the middle. Just to rub it in, I have 2 pairs of nib PROLINE M3 step pins, made less then a month ago
#315
