help on Mamba Max Pro >
Old 12-21-2009 | 10:07 PM
charlessito's Avatar
Default help on Mamba Max Pro
I am using a Flux 5700kv sensorless motor for my Mamba Max Pro but I just keep getting the clogging problem. I am using it for drifting as you know there will be alot of sudden brake and throttle. Tried uploading firmware but the clogging is still there.
Another of my friend was using a lrp sensored motor for the MM pro he also got the clogging problem.
can anyone with exprience for Mamba Max Pro help.
charlessito is offline
Old 12-22-2009 | 05:43 AM
Sounds like you both have a connection problem or your batteries are very poor.
The Flux 5700 motor is a Castle motor, and sensored should never cog anyways.
burnineyes is offline
Old 12-22-2009 | 07:05 AM
Check all connections to see if any are getting warm/hot - those prob need to be redone. If none found, suspect your batts are not up to what the motor is asking for, can you borrrow/try some better ones?
Duster_360 is offline
Old 12-22-2009 | 07:56 PM
tmaxx26power's Avatar
I'm running the Mamba Max Pro 5700kv combo and no cogging at all with both Lipo and NIMH.
tmaxx26power is offline
Old 12-23-2009 | 09:46 PM
have tried different top brand lipo but there is still a lack in responds. Connection all check no problem. By the way what kind of setting u guy did on the mm pro?
