help on Mamba Max Pro
I am using a Flux 5700kv sensorless motor for my Mamba Max Pro but I just keep getting the clogging problem. I am using it for drifting as you know there will be alot of sudden brake and throttle. Tried uploading firmware but the clogging is still there.
Another of my friend was using a lrp sensored motor for the MM pro he also got the clogging problem.
can anyone with exprience for Mamba Max Pro help.
Check all connections to see if any are getting warm/hot - those prob need to be redone. If none found, suspect your batts are not up to what the motor is asking for, can you borrrow/try some better ones?
