The Speed Passion Thread >
Like Tree57Likes
Old 12-16-2009 | 04:53 AM
  #1336
abailey21's Avatar
http://www.speedpassion.net/en/productDetails.asp?p=65
Look under the download section for the LCD box
There's a new software version 1.32
abailey21 is offline
Old 12-16-2009 | 05:10 AM
  #1337
dsyed1's Avatar
thanks Adam!!!!!!!!!!!
dsyed1 is offline
Old 12-16-2009 | 06:00 AM
  #1338
abailey21's Avatar
Also a small note, you can download the 1.31 in the same spot.
If you download the 1.32 you will have the newest stock spec software, but you will not have the 312. You would have to download the 1.31 to have the 312
Old 12-16-2009 | 06:09 AM
  #1339
sosidge's Avatar
Since the new stock software is public now, can you share what you have found in terms of gearing/motor timing changes to the 312? Or is it just a case of update, run it, TQ?
sosidge is offline
Old 12-16-2009 | 06:16 AM
  #1340
abailey21's Avatar
Gear WAY down lol
where guy were gearing at like 4.2 they're gearing closer to the mid 6's
I know Solara, and Seaball have run it I'm hoping they chime in with their findings as well.
Old 12-16-2009 | 06:21 AM
  #1341
Cain's Avatar
man I need to get my LCD programmer in to try this software!
Cain is offline
Old 12-16-2009 | 06:33 AM
  #1342
DirtyDog3375's Avatar
Gear WAY down lol
G'day Adam,
Just wondering was that with the new V3 SP motors (17.5t)? and what firmware do you suggest with new new 1.32 software?
DirtyDog3375 is offline
Old 12-16-2009 | 06:42 AM
  #1343
abailey21's Avatar
Originally Posted by DirtyDog3375
G'day Adam,
I'm seeing the majority of the guys that have run the new stock software have actually gone back to the 312 software.
So I would say 312
Old 12-16-2009 | 08:41 AM
  #1344
lastsun's Avatar
i am running the SP GT2 PRO with a 11.5T, what software should i use??
what is the difference with the term u guys r using... firmware and software??
sorry to ask silly question new to EP
lastsun is offline
Old 12-16-2009 | 08:49 AM
  #1345
abailey21's Avatar
firmware/software is the exact same thing, just depends on how you decide to say it.
For 11.5 I would use either the 323, or 312 for now
Old 12-16-2009 | 09:57 AM
  #1346
seaball's Avatar
i only dropped 3-4 teeth...
but, to be honest, i can't feel where gearing's good. brushed, yeah, that was no problem. brushless, eh, it all feels the same to me (short of being undergeared and revving out) at the moment.
the stock profile is alright. i really liked 312, and when i went over to 'stock' it seemed softer on the low end. good for some motors, maybe not for others. same laps, though, but i'm running on a 90ft track, and using a 13.5. i left the stock profile loaded for the NEGS race this weekend.
what i do know is that if you don't use the sensor wire with 'stock' loaded, the esc will not shift into the second segment of the profile. so, i'm deducing that it probably employs an rpm based trigger point where timing makes a step jump (to another fixed timing level). it's smooth, though. you can't tell at all on the track.
all that said, it's fine. but i think it's going to need to be tested in vta or on a long track with a slow motor to be better qualified as a true enhancement for the stock racer.
as always, it will appear faster when you take teeth off, due to the noise you'll hear when it spools up. and you'll get more braking effect (from the gear change). it may even pull better off the straight. but the times have shown no noteworthy improvement to me, thus far.
seaball is offline
Old 12-16-2009 | 10:01 AM
  #1347
Cain's Avatar
if the LCD Programmer comes in, I can try out the settings assuming the weather holds for VTA. this however would be with the following electronics, but the same type of cars (Academy STR4 Pro IIs, shaft drive)
- RFI 4000mah 25C Lipos
- Tekin 21.5 in one, Epic Duo 2 21.5 in another (I am going to set the timing to zero on both to try it out)
- Speed Passion GT2.0 Pro with the Tekin, GT2.0 LPF with the Duo 2
Cain is offline
Old 12-16-2009 | 02:33 PM
  #1348
Thank you Seaball....
Before the STOCK profile, I was running 323a with 4.8 final drive and DRRS 9, AMTS Max with stock motor (on motor) timing. Great setup.
I have ran 30 plus packs with the "stock" profile(s) the last 1.5 month and here is what I think..."stock" profile is good for 13.5 and faster motor (ie 11.5T), it has very noticable, improved brake/drag brake and motor temp is WAY COOLER then the previously unrelease "stock" profile.
Timing on the "STOCK" profile can be max (26.25*), DRRS are 8 or 9 (not much of a different). Gearing...at the most recent race, racing at a very short, tight carpet track....5.2 final drive is comparible to other speedo/motor for 13.5. (I was told others with Duo2 motor, LRP or TEKIN, were using close to 8.0 final drive). I would say 5.0 can be the MAX (unfortunitely I don't have the time to keep testing that). For longer and more open carpet track, I think we can gear just like the 323a software (and setting) and check lap time....it deifintely has the power, speed, just like Tekin and LRP.......but 1 cool thing is, when I was running the last 2 races with that profile. after 6 minutes of hard racing, my motor did not exceed 135*. That tells me I have plenty of ROOM to gear up....
Not that I would need to since the car has the power on the straight and infield but at least I know it won't fried the motor or getting the motor upset. I was testing on the new V3 13.5 and the 3 years old SP V1 13.5 black can and both came up pretty much the same.....my V3 was set @ 5* timing, plug at the center, default position.
May be I will go back to try the 312 for a 17.5 and 13.5 and do another comparison....but I know the 323 with 13.5 (DRRS 8/9, AMTS max, stock motor timing) with 4.8 final drive is very much a best all around setup for any carpet track....
Solara is offline
Old 12-16-2009 | 02:39 PM
  #1349
sosidge's Avatar
I have ran 30 plus packs with the "stock" profile(s) last 1.5 month and here is what I think..."stock" profile is good for 13.5 and faster motor (ie 11.5T), it has very noticable, improved brake/drag brake and motor temp is WAY COOLER then the previous unreleased "stock" profile.
Timing on the "STOCK" profile can be max (26.25*), DRRS are 8 or 9 (not much of a different). Gearing...at the most recent race, racing at a very short, tight carpet track....5.2 final drive is comparible to other speedo/motor for 13.5. I would say 5.0 can be the MAX (unfortunitely I don't have the time to keep testing that). For longer and more open carpet track, I think we can gear just like the 323a software (and setting) and check lap time....it deifintely has the power, speed, just like Tekin and LRP.......but 1 cool thing is, when I was running the last 2 races with that profile. after 6 minutes of hard racing, my motor did not exceed 135*. That tells me I have plenty of ROOM to gear up....
I'm not 100% sure what your message is here...
One one hand you are saying that the new stock profile has power like the Tekin and LRP, and on the other you are saying that the 323 (mod) profile is the best for 13.5.
So which is it?
sosidge is offline
Old 12-16-2009 | 02:40 PM
  #1350
mharlow's Avatar
What firmware would be the best to use for 4wd Offroad Mod using a 7.5 motor?
Also whats the difference with the new profiles 091110stock, 091107stock & 090731?
mharlow is offline
