KO Propo EX-10 EURUS >
Old 04-21-2015 | 12:08 PM
  #1711
lil-bump's Avatar
Originally Posted by legg.j
Man I have a 4pkrs I got last year. I drove my buddy car 44.3 with the KO radio boy! I miss that fell, The last time I had one in my hand was 2005 10 years ago when I had it. Will I be going backwards if I get one please honest opinion thanks.
You better hurry; I believe the Eurus has been discontinued.
Pass you soon...
lil-bump is offline
Old 04-21-2015 | 04:30 PM
  #1712
macdude's Avatar
Originally Posted by lazyboy12300
Had a search but not found anything,
Had an issue with my Eurus today, where the throttle lever is very sticky. As in it can get jammed at full throttle or brake, and has a very 'jammy' feel and not smooth. Thankfully it happened at the end of my run so didn't matter too much, but can't really drive with it as it is.
I was wondering if anyone has had a similar issue and if there is anything that is an obvious replace to fix this? It is 4 years old, so has had a lot of dirt/dust in it I would imagine, so going to open it up and check it out.
Cheers
Scott
Yes, I had a similar issue. I contacted KO and the replacement cost is pretty cheap. But you have to ship the radio to them. So I took the radio apart and looked at the POT, everything seemed ok just sticky. I adjusted the spring and put it back together. After about 4 runs the stickiness seemed to have fixed itself. Mine was so bad that the trigger was like in slow motion if I let go of it. Now it seems to be working fine. If yours does not get better I would just send it to KO. The fix is cheap.
macdude is offline
Old 05-23-2015 | 11:45 AM
  #1713
Hello!, do you think that the EX10 eurus is still a top radio compare with the new KIY?, is the extra cost of the KIY justified?
Raulote is offline
Old 05-23-2015 | 01:42 PM
  #1714
The eurus is still a great radio. Its not much different price wise. Performance on the kiy is a lil faster. Noticeable.. But. Its up to u..
dgrobe2112 is offline
Old 05-23-2015 | 02:14 PM
  #1715
vabroom's Avatar
I still think the Eurus is still a top radio but since KO killed it, it's hard to find receivers for it. Mine has the 902 module if I replace it with a 904 and 3 receivers it almost cost as much as a KIY.
vabroom is offline
Old 05-23-2015 | 03:20 PM
  #1716
Thanks!, I have the opportunity of buying one eurus with 904 module and KR-413 receiver or a KO KIY for about the same price both used.
Phisically I prefer the eurus, but in terms of performance I am not sure.....
Raulote is offline
Old 09-01-2016 | 08:34 AM
  #1717
Hi guys i have an issue with 1 receiver on my radio , a 407s , it seems don't want to bind on the radio ...
Folloow steps to bind it , and when i turn on the receiver while keep (setup button ) led turn off then turn on , and when i realease button led return off ...
My receiver is dead you think ??????
maximax is offline
Old 09-01-2016 | 08:49 AM
  #1718
your supposed to hold the button.. turn on the switch.. then release immediatly.. not keep holding it..
Old 09-01-2016 | 10:18 AM
  #1719
Yes that's what I made ... excuse me maybe I don't write this but that is what I made ... sorry for my English ...
I have test with another receiver and everything is ok ... so I think my 407 is dead...
maximax is offline
