8T 2.0
Old 10-29-2009 | 11:00 AM
  #4891
Default 8T 2.0
How are you guys getting the slop out of the rear wheels ? I've shimmed the backside with diff shims. They seem good, then after one run there loose again. I have the modded J-dub plastic rear hub carriers.
Is there a fix for this, or is this just what all truggy's do since the tires are so big ? Should I be shimming them differently ?
miket3 is offline
Old 10-29-2009 | 11:21 AM
  #4892
losi_racer's Avatar
dont shim it. losi likes slop
losi_racer is offline
Old 10-29-2009 | 12:31 PM
  #4893
Integra's Avatar
Trace the Slop back to where its coming from....are you Positive its not a ball end on the tower or knuckle....are you sure its not the knuckle itself slopped out on the 3.5mm hinge pin ? the alum balls have a tendency to slop out if you get your truck real dirty and don't clean it properly....If it's the Axle itself....you want a hair of slop...like .1-.2mm and no more....just enough to feel a "tick" of play in the axle to the wheel hex.....MAKE sure to check it with the Grub Screw Tight as that Will take up some of the slop.
Integra is offline
Old 10-29-2009 | 12:33 PM
  #4894
shady3031's Avatar
I think a lot of the slop is coming from the wheel hexes, so I swapped mine with a set of xray 808 hexes that I got off ebay for $15-huge improvement, no shimming and ir still has slop just not quite as much
Another local racer put the hexes off hos 1.0 buggy on his 2.0 truck and also liked the rrsults-it doesn't make the truck twitchy like shimming can if it gets too tight
shady3031 is offline
Old 10-29-2009 | 12:37 PM
  #4895
I put a little piece of electrical tape on the axle and it took out 80% of my slop in the rear wheels. The axles kind of "float" in the bearings which is what is causing the slop.
Edumakated is offline
Old 10-29-2009 | 11:54 PM
  #4896
Guest
Default I am new to the truggy racing
Tell me something guys? I just got a used 1.0 truggy, my first truggy ever. I was on eBay and found 3 sets of truggy half offset rims new for 51.56 shipped , will they fit the truggy, or not. And another question is does anyone on here have a good chassis for the 1.0 truggy I can buy from them, or tell me where to find a chassis like a flex tune? Thanks guys
LOSIRACER77 is offline
Old 10-30-2009 | 05:08 AM
  #4897
l3asher's Avatar
The half off set rims will work just fine, it comes with half off sets out of the box. For a chassis you can try ebay. They are not cheap.
http://cgi.ebay.com/Losi-A4403-Chass...item53dbfd7d56
l3asher is offline
Old 10-30-2009 | 06:43 AM
  #4898
Frank L's Avatar
If you are going to drop that kinda cash on a new chassis then get a 2.0 chassis from bce and a new rear center drive shaft. You will be verry happy.
Frank L is offline
Old 10-30-2009 | 06:49 AM
  #4899
Integra's Avatar
DONT waste your $$ on a dragon racing chassis either...there JUnk and Wont last more then a weekend or 2.
Integra is offline
Old 10-30-2009 | 03:45 PM
  #4900
dhopkins8's Avatar
Losiracer77
I have a Losi 8T 1.0 Chassis that is in pretty good condition that I was selling for pretty cheap if you are interested.
Pm me if you are.
dhopkins8 is offline
Old 10-30-2009 | 04:42 PM
  #4901
rhino420
Guest
Posts: n/a
so does anyone have a clue if they or if some one did come out with mud gaurds for the 8t 2.0 ?
Old 10-30-2009 | 05:59 PM
  #4902
Frank L's Avatar
I use the mugen ones they are curved and look very cool. I had to drill a new hole but ohh well, They work very well. Most guys I know cut down the 1.0 guards.
Frank L is offline
Old 10-30-2009 | 08:03 PM
  #4903
bigjayjay1's Avatar
currently I know no manufactures I even called message and talked too manufactures about making none have interest I bought the parma lexan and went too town.
bigjayjay1 is offline
Old 10-30-2009 | 10:54 PM
  #4904
RcRick's Avatar
I have a Brand new never run chassis for the 1.0 I will sell cheap.also have one that has about 3 runs on it If interested just PM me.Thanks,Rick
RcRick is offline
Old 10-31-2009 | 08:36 AM
  #4905
Integra's Avatar
I used some thin sheets of CF for mine but originally made them from the Parma Thick lexan.....you can also make them cover a lot more then what the 1.0's did.
Integra is offline
