8T 2.0
Old 10-01-2009 | 12:40 PM
  #4651
losi_racer's Avatar
Originally Posted by aznitronut
Just use drakes set up, it should be good at most tracks.
im using casey and billy set up which isnt posted on the site. i was just seeing if anything special is needing to be done. gotta remember this is my first time outta state so just trying to cover my butt
losi_racer is offline
Old 10-01-2009 | 01:00 PM
  #4652
SqueegUK's Avatar
I think I may have found part of the issue why my car was a dog on Sunday.
I just went and checked all my settings again and I noticed the front of the car would not sit on the 39mm block I have for it, even after dropping it????
Strange as I set the car up on the setup board, etc. and it was bang on 39mm front, now it's the same as the rear 42. What issues would this cause? How did it raise itself now, lol?
SqueegUK is offline
  #4653
SqueegUK's Avatar
Any chance you can pm me that setup please mate?
SqueegUK is offline
Old 10-01-2009 | 04:46 PM
  #4654
Douglas remember that they also are using the Rear Shock Tower that you dont have so that set-up isnt for everyone the ass-end is a little twitchy. That and Billy also runs the front smart diff in Truggy and I think Casey does as well.
Vareck is offline
Old 10-01-2009 | 05:42 PM
  #4655
losi_racer's Avatar
yes Vareck i know. Both casey and billy have suggested this set up to me. I know they have the different shock tower then us. But i really like it. I tried it last weekend a i loved it. I am going to try some alterations just like with any set up. I think i am going to try it with the stock ride height and droop this week
Old 10-01-2009 | 05:50 PM
  #4656
And add 2 ounces of weight on the rear of the chassis up against the rear hinge pin brace under the rear outdrive you should really like that then it plants the rear-end better.
Vareck is offline
Old 10-01-2009 | 09:38 PM
  #4657
losi_racer's Avatar
Ok ill try that. This set up just had so much more turning.
Old 10-02-2009 | 06:02 AM
  #4658
SqueegUK's Avatar
I am sure I read somewhere about changing the fuel tubing on the brake acutators. Can anyone please enlighten me on this?
I find that my brakes tend to go away as the day progresses to the point I have to up my EPA quite a bit, this has ended up with me burning out my Ace servo which has served me well for the past year and a half.
SqueegUK is offline
Old 10-02-2009 | 06:42 AM
  #4659
Integra's Avatar
sure your disc's aren't glazed over ?
Integra is offline
Old 10-02-2009 | 06:48 AM
  #4660
l3asher's Avatar
This will be my next set of brakes.
http://www.amainhobbies.com/product_...Set-20-Updated
l3asher is offline
Old 10-02-2009 | 06:52 AM
  #4661
SqueegUK's Avatar
I sanded them clean on 120 grit paper before the last race, so I woudln't have thought so, but then again, anything is possible, lol.
SqueegUK is offline
Old 10-02-2009 | 07:04 AM
  #4662
+1
Vareck is offline
Old 10-02-2009 | 07:21 AM
  #4663
Integra's Avatar
the tubing can have something to do with it...but like you said you increased the EPA through out the day to gain the brakes so i would assume the tubing is getting Firm from all the extra throw.....i would now start to look at the mechanical side of the brakes...why isn't it stopping as it should.
Integra is offline
Old 10-02-2009 | 07:37 AM
  #4664
SqueegUK's Avatar
Well, I have stripped the whole lot down and sanded the discs again and also roughed up the metal calipers as they looked very smooth. I also reset the screws as per Losi's recommendations, so I'll have to see from here I guess.
The fuel tubing on the actuators seems to be very hard though. I have had to adjust me EPA right down now, the servo hardly moves and I have some serious braking again.
SqueegUK is offline
Old 10-02-2009 | 08:34 AM
  #4665
Frank L's Avatar
I have been using those since they were released and so far they are more consistent than the stock brakes.
Frank L is offline
