Associated RC12R5
#1621
What speedy are you guys using for the 1S lipos?
I was looking at getting the Tekin RS Pro but id like a speedy that i can also chuck in my tourer that can handle mod. So possibly the SXX?
#1622
Hello guys, I am hoping some resident experts may be able to offer me some advice on getting into 1/12th racing.... first a little background, me and four of my nitro buddies are looking for something to run this winter, our local LHS has a medium sized indoor carpet track, they don't run too many races, but the track has great acess whenever its needed.... So me and my buddies are thinking of buying 5 of the same car and motor setup, just to make the learning curve easier.... Our LHS stocks the AE car with full compliment of parts, so I have decided the AE car is our best bet......A few of the guys were looking at the X-Ray M-18, but I feel the 1/12th cars would be more competent and robust.......... Anyways I would like to go BL with lipo , not looking for a overly fast motor, just something useable that we can develop our driving skills with.......... I am completely and utterly clueless when it comes to 1/12th racing, so I have no idea what direction to take.... We would be looking for the best servo possible ( durability is very important ), digital preferred.... Basically I am hoping someone here can take my hand and guide me to a good working setup that can get my group up and running with the least amount of trouble.... As I say we are all very green to to carpet racing and I fear without guidance we could easily go in the wrong direction and waste both time and money........ Also I am thinking we will start with AE newest offering http://www.amainhobbies.com/product_...ad-Pan-Car-Kit
Anyways hopefully a few of you guys have the time to help me, I have done some reading thru the threads, but honestly the threads are long and many things are over my head so finding what i am looking for is difficult....Thank you in advance !
#1623
Futaba 9650 servo with med servo saver
LRP SXX speedo.
Trinity or phantom 13.5 brushless motor.
72 spur
40 threw 45 pinion (64 pitch)
Protoform speed 12 (not the 12b)
Any 1cell lipo will do.
Small rx pack and regulator or booster (Im using the $5 china booster from hobby king)
Tires are your biggest exspense. Black front and yellow rear are a good place to start but get with the fast guys and see what your local track needs.
You will need to have or know some one with a tire truer.
If complexity is an issue then you can run 4 cell packs and a 17.5. That will get rid of the rx pack or booster. ITs just as fast as 13.5/1 cell.
When you get all that together then come back and we can get you a base setup to start them out with.
HTH
DK
#1624
Here Is my setup from the IIC.
Front end
.20 springs w/4 shims on the top and 30000 lube
1 1/2 * camber,full castor, 1/2* toeout
3.25mm ride height
Jaco magenta 41mm, 1/2 tire, jack
Rear
gold center and side springs
30wt in both shocks
3.25mm ride height
.75mm pod droop
Jaco magenta 43mm full tire, jack
Protoform AMR
Lrp Sxx 2,4,2,1
Reedy 1cell 4600 lipo
Lrp 4.5, 25/96
Hope this helps
Front end
3.25mm ride height
Rear
30wt in both shocks
3.25mm ride height
.75mm pod droop
Protoform AMR
Lrp Sxx 2,4,2,1
Lrp 4.5, 25/96
Hope this helps
#1625
Um, what makes you think the RS Pro won't handle mod in a sedan? The RS or RS Pro would be my choice in your situation . . .
#1627
#1628
http://www.petitrc.com/reglages/asso...tedRC12R5.html
Arn0 agreed to host my Vegas setups. So if you have called me, emailed me, or pm'd me you should be able to get them from petit R/C soon.
AWD
AWD
#1630
Are any of you running a JR servo in your 12R5 or 12R5.1? I recall reading that Sean C runs a JR servo. My question is... Did you drill new holes in the chassis to use the servo mounts or just Shoe-Goo the servo to the chassis? If you drilled new holes, did you flip the servo over so it is on the left side of the chassis and then mount the ESC on the right?
Thanks in advance.
Thanks in advance.
#1631
AE-Reedy
Thanks in advance.
Thanks in advance.
#1632
Sean, when are you going to start racing Thursday nights at OCRC again?
#1634
In doing a side by side between the 12r5 vs 12r5.1 manual these are the minimum parts you would need to purchase to make the conversion happen assuming you already own a 12r5.
Lower Pod Plate : 8511
LR bulkhead : 8537
Motor Mount Standoff : 4687
Motor Mount Plate : 8536
upper pod plate : 4688
ball stud 8mm long silver : 31284
aluminum 2mm washer : 31286
m3x5mm bhcs : 31530
Please note part# 4688 is not available till mid October 2009.
LR bulkhead : 8537
m3x5mm bhcs : 31530
#1635
AWD
AWD
