8T 2.0
Old 09-26-2009 | 01:28 AM
  #4591
aaron joy's Avatar
I think you will be alright Mark. If you like the aluminum shoes get some long wears in the future. I mix em up with carbons, I get 4 or 5 race days on a set of shoes before I replace them. I can relate on the bog, when I started 1/8 about 5 yes ago I had a RB WS7II that I had a Fioroni sliding clutch on with Teflon shoes. It was fine for warm up then halfway thru the heat race I would get a bog in the infield but would clear out on the straight. We found the clutch to be the problem.
aaron joy is offline
Old 09-26-2009 | 04:55 AM
  #4592
offroad racer's Avatar
Originally Posted by SqueegUK
Here is the list of the spring rates:
LOSA5456 - 15mm springs 3.1 x 2.5" Rate Red
LOSA5457 - 15mm springs 3.1 x 2.8" Rate Silver
LOSA5458 - 15mm springs 3.1 x 3.1" Rate Green
LOSA5459 - 15mm springs 3.1 x 3.4" Rate Black
LOSA5460 - 15mm springs 3.7 x 3.7" Rate White
LOSA5460 - 15mm springs 3.7 x 4.0" Rate Grey
LOSA5462 - 15mm springs 3.7 x 4.3" Rate Purple
Looks like using the purple is the only option to go harder. I might try that this weekend and see what happens.
Speaking of shock springs; are the springs in the back the same size as in the front?
offroad racer is offline
Old 09-26-2009 | 04:59 AM
  #4593
Originally Posted by Samson4721
What kind of .21's do you guys suggest in the $200 or less range?
The reason I ask is because most .21's I see say "Buggy" next to them. Does that mean they are underpowered for a truggy??
Stupid questions I'm sure, but I gotta ask
I have the same question
Old 09-26-2009 | 06:07 AM
  #4594
aaron joy's Avatar
No the springs are taller in the back, hence the 3.1 vs 3.7 in the chart posted.
These new dynamite engines are a great alternative in spending less money for a good mill.
This one is now shipping to your LHS.
http://www.dynamiterc.com/Products/D...ProdID=DYN0897
Old 09-26-2009 | 06:44 AM
  #4595
Frank L's Avatar
I persnally have bcome almost addicted to the os speed engines they are pricy but very very good engines. In the 200 range the weeks b5 is a great engine. A guy at my local tracks is getting great runtime with the B5 and a trinity bad boy pipe. You can't go wrong with the vspec engine either it's inthat range. If you want to spend a little more the new ninja bo1a is an awesome engine. It's almost a speed engine just less money. I would stay away from the reedy engine it is hard to tune and loves to run very hot or not at all. I hope that helps that's what I have seen do well at my local tracks.
Frank L is offline
Old 09-26-2009 | 07:05 AM
  #4596
Thanks Frank. I have really been looking at the B5. Sifting through it's thread for a few hours the past few days, it really seems to be a good motor. Plus you get customer support right on here pretty much. But it is currently out of stock....
Edit: What kind of run times and performance are you guys getting out of your stock losi 454 motor?
Samson4721 is offline
Old 09-26-2009 | 07:42 AM
  #4597
Frank L's Avatar
Call carolinasrc.com 1.888.RC CARS 8 and ask if they can get ahold of one. I know they dont list it on their site but tell them frank from CA sent you and you might be surprised.
Frank L is offline
Old 09-26-2009 | 08:01 AM
  #4598
Originally Posted by losi_racer
what color is the sway bar? i have a brand new sway bar set from my 1.0 so its not labled
Use your caliber if you dont have one bring it to the track and Ill show you Douglas
Vareck is offline
Old 09-26-2009 | 08:35 AM
  #4599
Man thanks again Frank. I am going to probably take you up on that in the next week or so. This axial .32 I threw in here to hold me over is just not going to cut it at all for racing. Anyone wanna buy it??
I am still curious how the losi 454 works though. You can get them real cheap and then I wonder how well it would do modded for run time.... I could possibly get multiples of that motor and set each up differently. Just thinkin big picture
Old 09-26-2009 | 09:05 AM
  #4600
Integra's Avatar
I would Highly recommend a race .21 over a .28 Any day.
Integra is offline
Old 09-26-2009 | 09:23 AM
  #4601
Ohhh I thought the 454 was a .26. Hmmmm anyone run a 427 in a truggy? How would that perform??
Probably just going to go for the B5 soon, but figured I would get all the info I can.
Old 09-26-2009 | 10:44 AM
  #4602
8&stuff's Avatar
have you ran one of these sg .21 mach 2 engines in a truggy? i have one in my buggy and havnt tried in truggy.
8&stuff is offline
Old 09-26-2009 | 11:20 AM
  #4603
losi_racer's Avatar
true i didnt think of that. you have a text btw
losi_racer is offline
Old 09-26-2009 | 12:11 PM
  #4604
reggie l.'s Avatar
i agree unless its a os.28xz with a 7mm carb and a os 2060...you can get 8-9min(MAABBEEE...) out of it..
i got 8:30 with one in my truck a few weeks back it was still new so tuned a little rich...(this is mybudys motor i let him use on my truck for a race)
on my ninja
(steel flywheel)...i run 2 composite on silver springs
and 2 alum on black springs..
reggie l. is offline
Old 09-26-2009 | 03:55 PM
  #4605
Integra's Avatar
on my ninja
My gripe about overpowering the truck is the wear and tear is put's the drive train through....its brutal compared to a race .21 Pins last 3-4X as long diff's dont need to be serviced as much...overall its less maintenance.....ive been there and Done that with High HP .28's....no thx.
question for ya reg...ninja being a .28 ? why the silver on comp's....the motor (if .28) has More then enough power to pull a way lighter spring and give you alot more life.
Integra is offline
