8T 2.0
Old 08-03-2009 | 06:33 PM
  #3991
mrbusta's Avatar
Originally Posted by vladconnery
As documented in the thread. The front wheels rub the A arm. I switched to the AKA rims however I still have rub.
My question is will the 2mm hub extenders cure this?
Also has anyone ever put there truggy on a Hudy system. If so did you notice with the 1's pointed out in the rear toe plate. Did you notice you were actually at 5 degrees toe and not 3. I put in the .5's in pointed out and I was still just shy of 4 degrees.
yip i noticed it all out and the toe plates are wrong as i did notice that what i did was put them in and see were they were are and the instruction manual was wrong
mrbusta is offline
Old 08-03-2009 | 06:34 PM
  #3992
Yes it fits the 2.0 also
bphil49 is offline
Old 08-03-2009 | 07:36 PM
  #3993
Integra's Avatar
Originally Posted by air8
Say someone messed up a rear hub on his truggy and the hobby shop only has 1.0 rear hubs. Which of the three holes in the 1.0 hub would be the same as Hole-B in the 2.0 hub?
2nd hole in....the extra hole in on the inside inside and is used in conjunction with the shorter links
the stock sheet is Wrong for the rear's....here's the proper #'s
Rear Toe-In adjustment
Position....Insert #....total toe-IN....REAL total
Inside........1.............1............1.65
Inside........0.5..........1.5.........2.15
Middle........0.............2............2.70
Outside......0.5..........2.5..........3.25
Outside......1.............3.............3.80
Rear Anti adjustment
Position....Insert #....total Anti....REAL total
UP..........1...............3............3.15
UP.........0.5.............2.5..........2.60
Middle......0.............2.............2.05
Down.......0.5.........1.5...........1.50
Down.......1.............1.............0.95
Originally Posted by CREWMAN
this may seem like a dumb question but i just want to make sure. is this starter box just for the 1.0 truggys ore does it also work fot the 8ight 2.0t
http://www.horizonhobby.com/Products...odID=LOSA99061
thanks in advance
they kept the footprint of the chassis the same and extended it on the rear behind where it hooks onto the box so its a direct drop on for 1.0 or 2.0 the 2.0 actually fits a little bit better.
Integra is offline
Old 08-03-2009 | 09:47 PM
  #3994
JAMMINKRAZY's Avatar
Actually the B hole in the 2.0 hubs would be the very inner hole on the 1.0 hubs. They added the 4th hole to the inside of the origional 3.
JAMMINKRAZY is offline
Old 08-03-2009 | 10:27 PM
  #3995
gone banana's Avatar
Originally Posted by sugelle
I know this is a bit off topic but I ran my 8T 2.0 yesterday for a few hours on the track and it was covered with dirt/nitro...filthy! I tried the S100 spray foam cleaner and have to say...IT WORKS GREAT!!! I didn't need to scrub anything...just spray the foam on and let it sit for a few seconds and then rinse it off (Removed the radio tray first..of course!). Hit is with air compressor to remove the water and I was done....less than 10mins total clean time. No residue or staining, plus no fumes like other nitro cleaners. This stuff is great!!! It comes in a large can that should last you a long time. You should be able to find it at any Harley dealer or motorcycle shop. I'll be buying more soon!
http://www.s100.com/s100_tcc.htm
I go to the dollar store & get can furniture cleaner a dollar a can spray it on air hose off and your done
gone banana is offline
Old 08-04-2009 | 05:07 AM
  #3996
offroad racer's Avatar
thanks in advance
I was wondering that too.
offroad racer is offline
Old 08-04-2009 | 06:46 AM
  #3997
Integra's Avatar
Hole B on the Older rear's is now hole C on the 2.0 rear's....that's how i meant to say it...but didn't want to go look at the manuals to figure out which A,B,C,or D
Hole B on the 2.0's is 2nd In from the inside....same with the 1.0's....#/letter starts from the inside.
Integra is offline
Old 08-04-2009 | 06:48 AM
  #3998
Integra's Avatar
Look up a couple posts.
Integra is offline
Old 08-04-2009 | 07:52 AM
  #3999
CREWMAN is offline
Old 08-04-2009 | 08:30 AM
  #4000
shady3031's Avatar
Definately need two sets of 2.0 rears-pm me your paypal and I'll make payment asap. Thanks and hope all is well.
Jason
Originally Posted by J-DUB
just wanted to let you all know that i am not gonna be offering modded hubs and spindles anymore i have 1 set of 1.0 rears and 8 sets of 2.0 rears and 3 sets of 2.0 fronts if interested hit me up and i will get them out asap they will be ready to ship tues thanks again j-dub.
they will be $31.50 shipped thanks again
shady3031 is offline
Old 08-04-2009 | 08:54 AM
  #4001
Muggydude's Avatar
Only two 2. rear hubs left boys, get em fast! I decided on and bought a .21 VSpec last night, as I still am only a sportsmen level driver.
Muggydude is offline
Old 08-04-2009 | 01:31 PM
  #4002
Hellsavage's Avatar
Is there a fix to prevent the shock caps from getting out of roundnes.
The shock stands where through the cap after a few gal.
Hellsavage is offline
Old 08-04-2009 | 01:33 PM
  #4003
losi_racer's Avatar
you have something wrong there, my old 1.0 has countless gallons on it, and my 2.0 has about 3-4 and mine are fine
losi_racer is offline
Old 08-04-2009 | 01:53 PM
  #4004
Integra's Avatar
Ive had a couple caps round out on me.....i just make sure the plastic insert that goes on the stand off first is in good condition and not worn down to allow the cap to round out easier.....please describe exactly what is happening to your caps ?
Integra is offline
Old 08-04-2009 | 02:00 PM
  #4005
Hellsavage's Avatar
Afer some time the edge of the shock stand wears itself in the cap. This makes the cap go leak where the edge kind of cuts a grove in the cap.
Specialy in the rear du to the extra too in at the rear.
