Mugen JX21
#571
ok. i have to ask this. How does the ninja compare to the speed. Unbiased opinions please. I know the ninja has the same coated crank but is it silicone filled as well. I would get a tko ceramic bearing as well.
ssoooo what are the differences and which one is better.
I am going to buy one of thease.
#572
#574
#575
truth of the matter is, both are capable of putting you into victory ln, the topend on both are very impressive, yes the 5 port vs 3 shows, but i like the JX because it does act more snappy on bottom, i like that for truggy and 1/8 latemodel.
#577
doesn't that contradict? shouldn't the speed have better bottom with the 3 ports? and how does the 5 vs 3 show? sorry if this seems like stupid questions.
#579
the rotating mass and the weight slows down the speed of the rotation, makes it smoother, and higher timing gets the topend going.
#581
i had this tuning trouble the last time so i start from the factory needle setting so far so good .........to dreaux just get the jx21 & ttr2035 or ae pipe it really match IMO you dont need the speed .........save that extra $$$ for something else period
#582
I have the PTM Ninja and run against speeds every week. Trust me, I'd much rather have the jx then a speed myself. It's got great snap on bottom, but doesn't seem to give up anything on top- at least at my track. Over 4 gallons on this one and it's strong as ever. Probably the best motor I've ever owned.
#583
i have a losi re11 will that work well with the ninja?
