Charger and Battery Question >
Old 07-10-2009 | 09:37 PM
Default Can someone tell me if this is a good buy?
Are the turnigy brand of lipo balance chargers a good brand? Is it a good charger? And are any brand of lipo good? Or if you can let me know some good brands of lipos that would work in a 1/16 scale revo. Type this number in ebay search to see what I'm talking about and let me know! shows lipos and that charger I was looking at Let me know what you think! #: 290327051581 Thanks!
P.S. This number also shows two other batteries 270423712627 Let me know if they are good?
gulfexports159 is offline
Old 07-11-2009 | 08:47 AM
Here is that charger from HobbyCity for $12, new -
http://www.hobbycity.com/hobbycity/s...110/240v_Input
Here are the Rhino 3S lipos, for $16 each -
http://www.hobbycity.com/hobbycity/s...0C_Lipoly_Pack
Shipping (express international) is like $30. The Ebay auction you linked seems overpriced.
The Rhono's have a good rep as long as you keep them balanced and don't discharge them too deeply.
The 2nd lipos - they're not a not choice for a Slash. But for a 16th E-Revo will they fit? They look long. These look like Flightmax lipos - more chinese lipos, again, prob ok as long as they're balanced and not too deeply discharged. Look on the HobbyCity site and see what other lipos you can find that size. This auction look a little more reasonable price wise.
Duster_360 is offline
Old 07-11-2009 | 10:44 AM
Default lipo
Have you ever bought from that website? Is it good? And will those fit the 1/16 revo?
Old 07-11-2009 | 11:37 AM
Yes, I've bought several times from that website and they are reliable and if you pay for the express shipping, you'll have your order in 4 or 5 days. The lower cost shipping takes right at 2 weeks. I've used both.
Which lipos the 2S or the 3S ones?
Over on the TRX forums, they are asying the batt box dimensions are 101.9mm x 35mm x 20.3mm (length x width x tall). The hard dimension to fit is going to be the heigth.
Old 07-11-2009 | 04:48 PM
Default lipo
Hey those 2 2200 lipos the blue ones I showed you on ebay he said he would give the mto me for 75 is that a good deal?
Old 07-12-2009 | 10:00 AM
Here they are, new -
http://www.hobbycity.com/hobbycity/s...idProduct=6540
They're $13 each, and int'l air mail would be about another $13. Looks like he is charging you double what they cost for his trouble of buying them and selling them to you.
You decide whether thats reasonable or not.
I'd buy them myself.
Old 07-12-2009 | 11:18 AM
Default lipo
So you think this is a good battery because your right I can get two for 51 on hobby king.
Old 07-12-2009 | 12:28 PM
They're decent lipos - take care of them, balance and don't routinely run them down to the lvc every time, you'll get your money's worth from them.
When I said I'd by them myself, I didn't mean from the eBay seller, but instead buy them directly from HobbyCity myself and cutout the middle man.
Old 07-12-2009 | 01:18 PM
Default lipo
Ok and what is lvc if you dont mind me asking? Also is that turnigy balance charger good? You know the one the was in the pic on ebay and then you gave me a link to it on hobbyking. Or if you know of a better one let me know. Thanks
Old 07-12-2009 | 01:30 PM
lvc - low voltage cutoff. Overdischarging a lipo will damage it - low voltage cutoff is about ~3.0v/cell, so for a 2S, that's 6volts. I personally use something a little higher 3.2v/cell, or 6.4v for a 2S lipo. This is typically set in the esc and if you don't have an esc that has a lvc, you install a separate one.
My experience with Turnigy products has been good, I'd expect it to be a good charger. The only prob I see with that charger is its intended for lipos about 1500mah in size. A 2200mah lipo is going to take over an hour. If the charge time doesn't bother you, it'll do the job.
Old 07-12-2009 | 01:36 PM
Default lipo
Well is there a faster charger thats not to hard on the wallet that you would recommend? If so let me know. I have a 1/16 scale revo and am looking at lipo thats why I'm asking all these questions cause I'm new to it. But, is there another lipo you would recommend for this car or should I stick with the flightmax?
Old 07-12-2009 | 01:37 PM
NEVADAGARY's Avatar
I just bought two of these...very nice batteries.
http://www.hobbycity.com/hobbycity/s..._15C_Lipo_Pack
And I have two of these..great charger.
http://www.hobbycity.com/hobbycity/s...idProduct=7028
NEVADAGARY is offline
Old 07-12-2009 | 01:52 PM
Can't beat the price, its only $12 (say $25 with shipping). A more capable charger is going to cost more, just no way around it, prob around $60. Trouble with this hobby is once you get started things start changing, you'll want to do more, buy bigger, run longer, get diff rc. The charger rapidly becomnes a limiting factor with any new of different plans.
The reviews and feedback have been good on zippy flightmax lipos, you won't find anything as good for the price. There are better lipos out there, but they are more expensive. Just make sure they will fit - TRX forums are saying the 16th E-Revo batt box is 101.9mm long x 35mm wide x 20.3mm high. Anything you buy has to fit.
Old 07-12-2009 | 02:15 PM
Default lipo
Ok but just seemed to good to be true because traxxas 1200 nimhs are 22.00. Now I can get a lipo cheaper than that. It will definitly be an improovment from the nimhs though right?
Old 07-12-2009 | 03:41 PM
There will be a def difference in running lipo vs NiMh. When I switched I was running 18th scale and my run time jumped 30% changing to lipo. The punch was pretty close to being the same as NiMh, but it lasted nearly the entire runtime instead of fading quickly (a few minutes) like NiMh does.
Plus with lipo its charge and run, no discharging or conditioning like you need to do if you're going to get the most/best from NiMh. You can run and recharge lipo as many times a day as you want, NiMh - can't do that.
There's a def difference.
