8T 2.0
Old 07-01-2009 | 03:06 PM
  #3376
Originally Posted by T0MM0
Matt .. i have run both smarts and loved the way it went but i am getting a lot of pizza cutting on the the front tyres so i was gonna try running just the front to see the results. Have you tried just the front?
Try removing two springs from the center diff and running just two .15s. That's what I'm running, and I really like it. I think a few of the pros are running that setup, and some are even cutting a few coils off of the two remaining springs.
Haven't personally tried a smart diff in front yet.
-Howard
pur3evil is offline
Old 07-01-2009 | 03:21 PM
  #3377
T0MM0's Avatar
-Howard
Hi Howard
I am running it like that now mate as well , with good results
T0MM0 is offline
Old 07-01-2009 | 03:24 PM
  #3378
T0MM0's Avatar
Originally Posted by mattwoodcraft
i have it was like running a one way in 1/10 sclae cars lots of turn in off power
Cheers .. i'll try it in practice and heat 1 to see if it suits and what the lap times are like
Thanx again
T0MM0 is offline
Old 07-01-2009 | 05:49 PM
  #3379
mattwoodcraft's Avatar
i havnt tried just running 2 .15 in the centre diff yet what is this doing in the way of handling engagement ?
mattwoodcraft is offline
Old 07-02-2009 | 08:17 AM
  #3380
steve307b's Avatar
I know its probably been posted many times, but my 8t 2.0 seems to push more so when I turn to the left then the right,(still does to the right), and I have to brake quite a bit to get it to turn tight. Can anyone make some ajustment sugestions, to get it not to push so much. I pretty much have it set up per the losi set up sheet in the manual. Thanks in advance
steve307b is offline
Old 07-02-2009 | 11:48 AM
  #3381
cornerspeed's Avatar
Reduce the rear to-in from 3.5 to 3
cornerspeed is offline
Old 07-02-2009 | 12:10 PM
  #3382
Frank L's Avatar
+1 on the 3 degrees in the rear. I run a king headz 3-3 block and 5k in the rear and it seems to work good.
Frank L is offline
Old 07-02-2009 | 02:39 PM
  #3383
jzemaxx's Avatar
+2 on the 3-3 block. I just bought the 2-3 block and am going to try it next. On a loose track where the front tends to push this maybe the ticket. Also going to try a little less front droop.
jzemaxx is offline
Old 07-02-2009 | 03:00 PM
  #3384
JAMMINKRAZY's Avatar
I have always run 3-3. On the 1.0, and now on the 2.0. I also run 3k in rear diff.
JAMMINKRAZY is offline
Old 07-02-2009 | 03:07 PM
  #3385
jzemaxx's Avatar
So far the 2K has worked for me. I think I may just keep working with the droop settings a little and maybe a little ride height adjustment.
jzemaxx is offline
Old 07-02-2009 | 05:18 PM
  #3386
vladconnery's Avatar
Finally took the plunged and joined the 2.0 club. Now I'm just asking myself why did I wait so long. This Truggy is much better in than the 1.0. Finally somebody put out a car Buggy or Truggy with definite improvements. Anyone have any advice for me or watch out for's?
I'm running
Jammin JPX .21 (JP4)
steering JR 9100T
Throttle JR 9100S
Smart Diff center
Contemplating smart diffing the front as well.
Side note I was using the Losi lipo and regulator. For whatever reason it started making me lose connections. Went back to NImh packs no more problems. Just in case anyone runs into the same issue.
vladconnery is offline
Old 07-02-2009 | 05:38 PM
  #3387
Frank L's Avatar
I had to up the rear to 5k when I added the front and center smart diffs the truck just has too much steering.
Frank L is offline
Old 07-02-2009 | 10:42 PM
  #3388
steve307b's Avatar
Thanks guys... I'll try the 3-3 toe in the rear. seems to be the ticket
Old 07-02-2009 | 11:37 PM
  #3389
CaseyP's Avatar
Billy Fischer and I have been working with truggy getting ready for the nats and have found a few things that the truck likes;
lighter rear bar, softer rear springs and a shorter rear camber link give it a try and see what you think.
CaseyP is offline
Old 07-03-2009 | 12:02 AM
  #3390
what is the effect with the shorter camberlink?
i like the stiffer rear sway bar more because here in europe are more technical tracks with more corner speeds, i need the car more stabel and thats the reason why i put the 3.00 sway bar from the 1.0 buggy in my 2.0 truggy
mihael
mihaelbencek is offline
