Airtronics M11X
#68
Hi,
i have a M11x too, and its a beautiful transmitter, i really like the steering wheel
But i have a question: The Antenna on the receiver is very long, so I wanted to ask if i can shorten it ?!? I had the Sprektrum SR3500 before and the antenna was very short, what i really liked
EDit: Are there Lipo packs for it out now?
Mike
Mike
#70
1st question you can not shorten wire
2nd impulse has a 2500 lipo pack that fits perfect just have to put airtronics z connector on it.
3rd you can turn sounds off i think it is in the user menu if I remember right
#71
Don`t cut that wire or rather its "coaxial cable" actually....
You can bend it into curves but never cut or kink the cable ...
Alert! Make sure that Li-Po mentioned is the correct voltage, M11x uses 7.2 volt....
All the tones can be customized ..
The instruction manual is most excellent & complete . Everything you wish you know how to adjust is easy to learn with the new instructions .....
#73
#75
Reason I said is measurements say its .68 thick & only .50 available inside transmitter ...
I did`nt think it would fit...
PS Its a 2500 , the battery that come with is 1500 and lasts about a hour..
so I would estimate you will get a extra 40 min ....
