Airtronics M11X
Old 06-23-2009 | 05:26 PM
  #61
mattwoodcraft's Avatar
this is the best dam radio i have ever owned m11x awsome
mattwoodcraft is offline
Old 06-24-2009 | 09:34 PM
  #62
Wonderkid's Avatar
Default M11x
hi all, whats the diff between FHSS & DSSS?
Wonderkid is offline
Old 06-25-2009 | 06:20 AM
  #63
dss locks in to a specific 2.4 frequency
fhss hops from channel to channel automatically
jinxed is offline
Old 06-28-2009 | 05:02 AM
  #64
So which is actually more ideal or better? I'm thinking whether to buy a 2.4 set(DSSS) or just get the M11x(FHSS).. If i'm not wrong. both are different 2,4g system....
Thanks......
backplate is offline
Old 07-01-2009 | 11:42 AM
  #65
fhss-2 is newer technology better times too i think
jinxed is offline
Old 07-08-2009 | 05:20 AM
  #66
F-1
Hello, how i can change the model in menu?? I cant. I go to MODEL menu, after that i go to SELECT menu, push + and - buttons for choose the model, and i view on display - DISPLAY MODE ONLY. What is it?
F-1 is offline
Old 07-08-2009 | 05:25 AM
  #67
...hold the display button to the right for three seconds and it will enter the program mode for your models.
exotica is offline
Old 07-08-2009 | 05:35 AM
  #68
Hi,
i have a M11x too, and its a beautiful transmitter, i really like the steering wheel
But i have a question: The Antenna on the receiver is very long, so I wanted to ask if i can shorten it ?!? I had the Sprektrum SR3500 before and the antenna was very short, what i really liked
EDit: Are there Lipo packs for it out now?
Mike
walsmi is offline
  #69
F-1
Thank you!! And can i turn off sounds?
F-1 is offline
Old 07-08-2009 | 07:21 AM
  #70
1st question you can not shorten wire
2nd impulse has a 2500 lipo pack that fits perfect just have to put airtronics z connector on it.
3rd you can turn sounds off i think it is in the user menu if I remember right
jinxed is offline
Old 07-08-2009 | 11:55 AM
  #71
Wild Cherry's Avatar
Tech Legend
Don`t cut that wire or rather its "coaxial cable" actually....
You can bend it into curves but never cut or kink the cable ...
Alert! Make sure that Li-Po mentioned is the correct voltage, M11x uses 7.2 volt....
All the tones can be customized ..
The instruction manual is most excellent & complete . Everything you wish you know how to adjust is easy to learn with the new instructions .....
Wild Cherry is offline
Old 07-08-2009 | 11:58 AM
  #72
the lipo mentioned is 7.4
jinxed is offline
Old 07-08-2009 | 12:09 PM
  #73
Tech Legend
Yes , that voltage would work. However ,check the dimensions. That particular battery will not fit inside the transmitter...
Just so you know...
Old 07-08-2009 | 12:27 PM
  #74
????? It is sitting in my transmitter just fine? That is one that was recommended to me by Airtronics factory driver should last a 3 day weekend without charge
jinxed is offline
Old 07-08-2009 | 12:59 PM
  #75
Tech Legend
Reason I said is measurements say its .68 thick & only .50 available inside transmitter ...
I did`nt think it would fit...
PS Its a 2500 , the battery that come with is 1500 and lasts about a hour..
so I would estimate you will get a extra 40 min ....
