Engine Shim Tuning >
Engine Shim Tuning
Engine Shim Tuning
Old 02-22-2004 | 09:20 AM
  #106
smartdriver's Avatar
Default REX P5 shim tuning
Motorman,I was wondering if you have any experience with this engine and what would be a good starting point for 1000 foot elevation ,high humidity,offroad. It currently has .21 head clearance and running 30% fuel.also do you have any reccomendations for break in processes as the novarossi manual is rather vague.....
smartdriver is offline
Old 02-22-2004 | 10:23 AM
  #107
stefan's Avatar
In case Dennis won't have an answer, you'll find lots of info here:
http://www.rc-racing.com/cgi-bin/pw/...howforgotten=2
stefan is offline
Old 03-01-2004 | 07:34 PM
  #108
jag's Avatar
jag
Motorman, I am new to this site and have learned a lot from this thread but I do have one question. I have an RB X12 5 port turbo in my Serpent Impulse Pro and I want to change from 20% to 30% nitro. It has the stock shim (approx. .015", I don't have a digital micrometer) and I read elswhere that you are supposed to add a .01mm (?) shim if you want to run 30%. Based upon the info here that would seem incorrect. Do you agree? I would really like to know what you think. I live in So. Fla (hot, humid and +10' above sea level). I would also like a glow plug recommendation please. I have an MT-12 I am putting in my truck and the info you gave on that was perfect.
Thanks,
jag
jag is offline
Old 03-12-2004 | 06:49 AM
  #109
afm's Avatar
afm
Default SHIMING A .21 ENGINE
MOTORMAN or anybody with experience, can you post the basic guidelines for correctly shiming a .21 engine???
Lets say an Off-Road Nova .21 based engine using 20% Nitro at sea level, what would be the ideal total chamber?? and the recommended Glow Plug??
Air temps are between 15 and 21° C and humidity around 75% to 85%.
AFM
afm is offline
Old 03-17-2004 | 11:31 AM
  #110
afm's Avatar
afm
Default Re: SHIMING A .21 ENGINE
AFM
Anybody care to comment on above
AFM
afm is offline
Old 03-17-2004 | 06:41 PM
  #111
I am planning to get a Novarossi NSR12S5 or NS15S5 engine and they both come with 0.3mm head shim (correct me if i am wrong)
I will be running 20% fuel. In that case, Do i need to add 0.1mm head shim to get proper compression?
Thanks.
US_MATRIX is offline
Old 03-30-2004 | 12:05 AM
  #112
ziggy12345's Avatar
I just got one and the manual says 0.3mm is perfect for 0-20% nitro and 0.4mm for 20-30% so should be ok with 0.3mm
ziggy12345 is offline
Old 11-27-2007 | 10:27 PM
  #113
speed006's Avatar
Can anyone here tell me where I'd find a degree/timing wheel small enough to use on a .21? My best friend has been building some BALLISTIC engines by "making adjustments" to the port timing on his sleeves with a Dremel. I'd like to get him a timing wheel for Christmas.
speed006 is offline
Old 11-28-2007 | 05:01 AM
  #114
keavze's Avatar
quick question:
if engine is losing compression, will removing shims helps to boost compression?
keavze is offline
Old 11-28-2007 | 05:08 AM
  #115
razzor's Avatar
Speed - you can buy yourself 2 protractors or print one from http://www.ossmann.com/protractor/
Keavze it can help but not for long.
Your options are to have the sleeve pinched or buy a piston/sleave set or just get another motor.
For 16% we found .35mm clearance to be ideal and .4/45mm gave a tad more rpm but lacked bottom end.
razzor is offline
Old 11-28-2007 | 05:34 AM
  #116
keavze's Avatar
what do u mean by 'pinching' the sleeve?
keavze is offline
Old 11-28-2007 | 07:05 AM
  #117
Pinching is expanding the piston or making the sleeve smaller for a tighter fit.
Roelof is offline
Old 11-28-2007 | 11:25 PM
  #118
keavze's Avatar
ok but how do i do that?
keavze is offline
Old 11-28-2007 | 11:33 PM
  #119
razzor's Avatar
Check with your local racers, usually there is one or two guys that pinch sleeves. Even try the local hobby shop.
Basically its squeezing the sleeve just a bit to give the piston a better fit.
It does give just that little bit more life out of your engine and chanmging the rod would be recommended too.
razzor is offline
