Difference in Futaba Rx's >
Old 06-10-2009 | 06:09 AM
Default Difference in Futaba Rx's
What is the difference between the 603FF (89.99) and the 603FS (99.99)?
piranha21 is offline
Old 06-10-2009 | 06:24 AM
603FF has dual - internal/external antennas, it detects whether HRS or PPM is active from tx and adjusts accordingly and has a fail safe for low rx voltage.
603FF has only the external antenna. Looks like its only available in 3 channels.
Duster_360 is offline
Old 06-10-2009 | 08:24 AM
Cpt.America's Avatar
That clears that up I guess...
Cpt.America is offline
Old 06-10-2009 | 09:38 AM
Rick Vessell's Avatar
FS is dual antenna
FF is single antenna
FS switches automatically between PPM and HRS when detected.
There is no built in F/S for either receiver. You're still dependent on setting the F/S settings in your TX which the RX defaults to if it loses signal. If you run low on voltage or lose battery there is nothing to power the RX to maintain the F/S.
Rick Vessell is offline
Old 06-10-2009 | 11:55 AM
FYI, you can get the FS (dual antenna) from stormerhobbies.com for $89
Old 06-10-2009 | 12:07 PM
http://www.futabarc.com/radioaccys/futl8926.html
